Background-position CSS confusion with percentage values?
  • Topic: HTML/CSS
  • Thread starter shivajikobardan
    Confusion Css
9 replies · 3K views · last reply
shivajikobardan
TL;DR
percentage value in background-position property. What happens there?
This is my background image.
Plain black outline of a circle on a white background, the kind of unfilled circle image used as a CSS background.
I set:
background-position:50% 50%;
I get this as my output:
Yellow-green page with the text "my name is tommy" at top left and a large white circle with a thick black outline cropped at the top edge, its bottom centred horizontally.
But I don’t understand the output.
So, I read little bit about background-position again.A value such as 20% 65% specifies that the point 20% across and 65% down the image be placed at the point 20% across and 65% down the element.
https://www.htmlhelp.com/reference/css/color-background/background-position.html
With a value pair of '14% 84%', the point 14% across and 84% down the image is to be placed at the point 14% across and 84% down the padding area.
https://wiki.cdot.senecacollege.ca/wiki/CSS_GUIDE_BACKGROUND_POSITION
A horizontal value of 25% positions the point 25% from the left edge of the image at a point that is 25% from the left edge of the background positioning area.
“Learning web design” by Jenniver Nierdest Robbins
If I wanted to put the background image at the center using the “percentage percentage”, how’d I do it? (50% 0% doesn’t work).
My HTML Code:
Code:
<!DOCTYPE html>
<html lang="en">
<head>
    <meta charset="UTF-8">
    <meta http-equiv="X-UA-Compatible" content="IE=edge">
    <meta name="viewport" content="width=device-width, initial-scale=1.0">
    <title>Document</title>
    <link rel="stylesheet" href="style.css">
</head>
<body>
my name is tommy
</body>
</html>
My CSS code:
Code:
body{
    background-color:yellowgreen;
    background-repeat: no-repeat;
    background-image: url(../images/circle.png);
    background-position:50% 0%;
CSS Code is tamed CSS code in background position just for reference.
shivajikobardan said:
I set:
Are you sure? That looks to me like background-position: 50% 0%;
Then use background-position: center;
No, this should be obvious. You want background-position: 50% 50%;, but why make life hard for yourself? background-position: 50% 50%; = background-position: center center; = background-position: center;.
What does this mean?
isn't producing expected results like you said.
Perhaps the body doesn't have any height. Try adding height: 100vh;.
now, I'm getting different output when I try the same code with the image posted here.
And why is that unexpected after changing the code?
wow. this fixed. I didn't get the reason why this fixed? Body doesn't have height without us specifying?
I'd missed that update of pbuk.
Like any block element, the <body> will only have (inner) height if it has content, or if it is set as an attribute or in CSS.
thank you.
