Backward euler method for heat equation with neumann b.c.
The discussion focuses on solving the heat equation using the backward Euler method with Neumann boundary conditions in MATLAB. The original code provided by the user contains errors in the implementation of boundary conditions and matrix setup, leading to incorrect results. Key issues identified include incorrect initialization of boundary values and improper handling of the matrix for the backward Euler method. The corrected approach involves ensuring that boundary conditions are accurately represented in the matrix and vector formulations.
  • Understanding of partial differential equations (PDEs), specifically the heat equation.
  • Familiarity with numerical methods, particularly the backward Euler method and finite difference methods.
  • Proficiency in MATLAB programming for implementing numerical algorithms.
  • Knowledge of boundary conditions, especially Neumann boundary conditions in PDEs.
  • Review MATLAB's sparse matrix operations for efficient numerical solutions.
  • Learn about the stability and convergence criteria for the backward Euler method.
  • Explore the implementation of central difference approximations for spatial derivatives.
  • Investigate the effects of different boundary conditions on the heat equation solutions.
Mathematicians, numerical analysts, and engineers working on heat transfer problems, as well as MATLAB developers seeking to implement numerical methods for PDEs.
omer21
I am trying to solve the following pde numerically using backward f.d. for time and central di fference approximation for x, in MATLAB but i can't get correct results.
<br /> \frac{\partial u}{\partial t}=\alpha\frac{\partial^{2}u}{\partial x^{2}},\qquad u(x,0)=f(x),\qquad u_{x}(0,t)=0,\qquad u_{x}(1,t)=2<br />
for boundary conditions i used the following approximation
u_{x}(0,t)=\frac{u_{i+1}^{j}-u_{i-1}^{j}}{2h}
what is wrong with the code i wrote
Code:
function [T,exact]=implicitheat2(t_i,t_f,a,b,dx,dt,alpha)
%U_t=U_xx , 0<x<1, U(x,0)=x.^2+1+cos(pi.*x), U_x(0,t)=0, U_x(1,t)=2
% dt: step size in t
% dx: step size in x
% a: left point of domain
% b: right point of domain
% alpha: equal to 1
% call func. as implicitheat2(0,0.1,0,1,0.1,0.00001,1)
n=(t_f-t_i)/dt;
m=(b-a)/dx;
lambda=alpha*dt/dx^2;
if isinteger(m)==0
    m=round(m);
end
if isinteger(n)==0
    n=round(n);
end
T=zeros(m+1,n+1);
x=a:dx:b;
t=t_i:dt:t_f;
u0 = x.^2+1+cos(pi.*x);
T(:,1)=u0; %initial value
A = sparse(m-1,m-1);
    for i=1:m-1
        A(i,i-1) = -lambda;
        A(i,i ) = (1+2*lambda);
        A(i,i+1) = -lambda;
    end
A(1,2)=-2*lambda;
A(end,end-1)=-2*lambda;
b=zeros(m-1,1);
for j=2:n+1
    b=T(2:m,j-1);
    b(1,1)=T(2,j-1)-2*0*lambda*dx;  %T(0,j-1)-2*lambda*U'*dx
    b(m-1,1)=T(m,j-1)+2*lambda*2*dx;  %T(m+1,j-1)+2*lambda*U'*dx
    T(2:m,j)=A\b;
end
T=T(:,1);
%exact soln
[xx,tt]=meshgrid(x,t);
exact=2.*tt+xx.^2+1+exp(-pi^2.*tt).*cos(pi.*xx);
exact=exact(end,:);
Hey Omer21,
I will have a look at this a bit later. Also, could you check your initial vector u_0? I plotted it and I have
<br /> u\left ( 0,0 \right ) =2\\<br /> u\left ( 1,0\right ) = 1<br />
J.
Initial vector is right. You miss subscript at b. c. i guess. B.C's are specified at the derivative of u.
Whatever. If you want a discontinuous function as boundary condition, that's your right.
Without having looked further, I see you are missing a
Code:
T(m+1,j)=2;
in your main loop. Also, the following lines are suspicious:
Code:
T=T(:,1);
First: you multiply by 0. You sure? And for the second, you are doing a bunch of calculations and then taking only the first column.
You are right about
Code:
T=T(:,1);
. It ought to be
Code:
T=T(:,end);
I want to show what i did so i multiplied by 0 because of u&#039;_x(0,t)=0.
I put
Code:
T(m+1,j)=2;
just after second for loop but still i can't get correct results.
I redid your code. I think there is more to it than "just" backward Euler not working.
As I mentioned -
- Your initial vector first and last elements are not 0 and 2;
- You are assigning weird things in weird ways;
- Your "exact" solutions doesn't have value 0 for x=0 and value 2 for x=1, which are your space boundaries.
Here is my code in Octave. Feel free to inspire yourself. I will add the averaging with forward Euler to increase the precision.
Code:
function Y=heattrans(t0,tf,n,m,alpha,withfe)
# Calculate the heat distribution along the domain 0->1 at time tf, knowing the initial
# conditions at time t0
# n - number of points in the time domain (at least 3)
# m - number of points in the space domain (at least 3)
# alpha - heat coefficient
# withfe - average backward Euler and forward Euler to reach second order
# The equation is
#   du             d2u
#  ---- = alpha . -----
#   dt             dx2
if (or(n<3,m<3))
 disp("Really mate?!")
 Y=[]
 return
endif
dx=1/(m-1);
dt=(tf-t0)/(n-1);
# Initial conditions are
# U(x,0) = x.^2 + 1 + cos(pi*x)
# Warning - U(0,0) = 2 =/= U(0,t=/=0) = 0
# and     - U(1,0) = 3 =/= U(1,t=/=0) = 2
x=linspace(0,1,m);
t=linspace(t0,tf,n);
beta=(alpha*dt)/(dx^2);
# Let's initialize our values
Ut=x.^2+1+cos(pi*x);
# Main loop - We apply backward Euler and solve successive equations
# Second order differences are computed using central difference, backward Euler is computed
# using the classic "one side" difference
for k = 1:n
  # Let's build the matrix of diff factors
  M=spalloc(m,m,3*m);
  M(1,1)=1;
  M(m,m)=1;
  for l = 2:(m-1)
    M(l,l-1)=beta;
    M(l,l)=-(2*beta+1);
    M(l,l+1)=beta;
  endfor
  # Now, let's build the vector of diff terms
  # That's actually -Ut, except for the first and last elements
  D=-Ut';
  D(1,1)=0;
  D(m,1)=2;
  # And the next step is the solution (transposed, as I use line vectors for U)
  Ut=(inv(M)*D)';
endfor
# The answer is in the last Ut
Y=Ut;
endfunction
Actually my codes are working accurately when B.C.s are dirichlet, but when B.C.s are turned to Neumann i confused how to edit the codes anyway i will look your codes.
Thank you jfgobin for your help.
Okay, I think I know where the problem lies. Part here, part there.
I will write some code later.
Here is the code that solves it. Don't forget that both backward Euler and forward Euler are methods of the first order, and that imprecision can creep up.
My code doesn't use central difference for the first order derivative: the only cases I need them is for the corners. A better approximation could be made by taking more points.
Code:
# The equation is
#   du             d2u
#   dt             dx2
if (or(n<3,m<3))
 Y=[]
 return
endif
dx=1/(m-1);
dt=(tf-t0)/(n-1);
x=linspace(0,1,m);
for k = 1:n
  M=spalloc(m,m,3*m);
  M(1,1)=-1;
  M(1,2)=1;
  M(m,m)=1;
  M(m,m-1)=-1;
  for l = 2:(m-1)
    M(l,l-1)=beta;
    M(l,l)=-(2*beta+1);
    M(l,l+1)=beta;
  endfor
  D=-Ut';
  D(1,1)=0;
  D(m,1)=2*dx;
  Ut=(inv(M)*D)';
endfor
Y=Ut;
endfunction
Attached are two plots, one at t=0.05 and one at t=1. Is that what you are looking for?
Your plots are correct. Thank you for your effort.
  • · Replies 0 ·
  • · Replies 28 ·
