Ball and air resistance (curiously difficult)
The discussion centers on the effects of air resistance on a ball thrown vertically with an initial velocity \( v_0 \) from a height \( h \). The air resistance is modeled as \( F_{\text{air}} = -bv \), where \( b \) is a constant. The time taken to reach maximum height in the presence of air resistance is given by \( t = -\frac{m}{b} \ln \left( \frac{1}{1+\frac{bv_0}{gm}} \right) \). It is concluded that the ball will rise and fall slower in the presence of air resistance compared to a vacuum, as it loses kinetic energy to both gravity and air drag, potentially reaching a terminal velocity during its descent.
  • Understanding of Newton's laws of motion
  • Familiarity with basic calculus, particularly logarithmic functions
  • Knowledge of forces, specifically gravitational and drag forces
  • Concept of terminal velocity in physics
  • Explore the derivation of projectile motion equations with air resistance
  • Study the concept of terminal velocity and its calculation for different materials
  • Investigate the effects of varying drag coefficients on different shapes and sizes of objects
  • Learn about the physics of motion in viscous fluids, such as molasses
Physics students, educators, and anyone interested in understanding the dynamics of motion under the influence of air resistance and other drag forces.
nicholaslyz
Hi,
I was wondering in my physics class the other day, whether if you throw up a ball from a height say h with velocity v0 , facing air resistance Fair=-bv on its way up and down, would it reach its initial height h again faster or slower than if you were to throw it up in a vacuum (i.e. Fair=0)?
It's hideously complicated...for starters the time taken for the ball to reach its maximum height in the presence of air resistance is t =- \frac{m}{b}\ln \frac{1}{1+\frac{bv_0}{gm}}
You can check this by \lim_{b \to 0}\Big(\textstyle \frac{-m}{b} \ln \frac{1}{1+\frac{bv_0}{gm}}\Big)=\frac{v_0}{g} , so if b = 0 then the equation is the one for time taken to reach the maximum height in vacuum.
So does the ball rise and fall faster in air resistance?
How would say a steel ball behave different in molasses??
It's a frictional force...analogous to frictional drag on an inclided plane...
Am unsure what you imply by "faster"...
the object will slow down faster as it initially rises because it is doing work (losing kinetic energy) against gravity AND air resistance. so it will not rise as far...then it falls more slowly due to air drag...and might reach some terminal velocity...
I don't intuitively see whther it will remain airbore for a different period of time or not.
I check projectile trajectory formulas...for example, a horizontally fired projectile falls according to vertical d = 1/2gt2 when ignoring air resistance; there should be some standard formula around for the effects of air drag...maybe that will help.
18K
