Ball bouncing off wall at angle momentum problem
4 replies · 1K views · last reply
David112234
m1v1+m2v2=m1v1+m1v1 after
my answer = -1m1v1
because the wall is not moving so its velocity is 0
therefore
m1v1 = m1-v1 after
I put -v because it is the same just bounces in the opposite X direction
I found somewhere online the answer should be 2 * mv * sin(θ)
I don't understand why
therefore
m1v1 = m1-v1 after
Conservation of momentum only applies to a closed system, i.e. no outside forces. The wall exerts a force. If you include the wall, the Earth exerts a force on the wall. If you include the Earth then in fact it will acquire a velocity from the impact, but so small you could not possibly measure it.
Just consider the change in momentum of the ball (as a vector).
It is the same as before only its x component changes, first it goes right, then it goes left
The magnitude is the same as before, but momentum and velocity are vectors. What is the net change in velocity?
Oh so I do vector addition
I did the math out and got the same answer, thank you
