What is the trajectory of a ball thrown from a building?
  • Thread starter Thread starter Eiano
    Ball Building
The discussion focuses on the physics problem of a ball thrown from a 60-meter high building with an initial velocity of 30 m/s upward. The time to reach maximum height is calculated to be 3 seconds, resulting in a maximum height of 15 meters above the building. Participants clarify that the initial velocity (vo) is indeed 30 m/s and suggest using the equations of motion, specifically x = x0 + v0T + ½aT², to find the total time the ball is in the air and its velocity just before impact. The importance of considering both the ascent and descent phases of the ball's trajectory is emphasized.
  • Understanding of kinematic equations in physics
  • Familiarity with concepts of initial velocity and acceleration due to gravity
  • Knowledge of maximum height calculations in projectile motion
  • Ability to apply conservation of mechanical energy principles
  • Study the kinematic equations for projectile motion in detail
  • Learn how to apply conservation of mechanical energy to solve motion problems
  • Explore examples of free-fall motion and its calculations
  • Practice solving similar problems involving initial velocity and height
Students studying physics, educators teaching kinematics, and anyone interested in understanding projectile motion and its applications.
Eiano
Hello!
I've been working on this problem for a while and our book doesn't have a solutions manual. It has 4 parts to it and I've solved 2 already, (I think) and the last 2 are just getting to me.
-A ball is thrown from the top of a building and is given an initial velocity of 30 m.s upward. The building is 60M high.
1). Determine the time needed for the stone to reach its max height
vf=at+vi
-30=-10t, t=3
2). Maximum height?
d= .5AT^s +viT
.5(-10)(3)^2+30(3)
= -5(9)+ 90
=15M
Velocity of the ball just before it hits the ground and the total time the ball is in the air?
What i did was
x=volt +.5AT^2 and solved for T but that can't be right because the answer i get is less that 7 seconds, and question following this says find the velocity and position at 7 sec. so it has to be AT LEAST 7 sec.
then i substituted that t for v=vo+at. so really, the 4th question is not the problem it's the 3rd.
Any help is appreciated
What i did was
Why do you have volt? vo is supposed to be zero (this is the velocity in the beginning).
So you need only x = ½gt^2 and after that v = at.
(Or you can use conservation of mechanical energy mgh = ½mv^2).
KingOfTwilight said:
Why do you have volt? vo is supposed to be zero.
So you need only x = ½gt^2.
isnt Vo the initial velocity which is 30 m/s?
I shouldn't be doing this in the night... I'm making mistakes all the time, sorry.
You know the time to go to the max height. Then you can calculate the time to drop from that height to the ground and use the knowledge in my 1st post.
EDIT:
After clearing my mind: yes you can use the one below too.
Check the answer by doing the both approaches.
Oh, sorry, yes it is. So, you will have to use x = x0 + v0T + ½aT^2.
x0 is the height of the building.
ahh i forgot the x0, you are right, thank you!
EDIT:
it's okay! at least there was someone out there to help me. again, i appreciate it!
Thanks. :)
  • · Replies 31 ·
10K
