Balls connected by string--momentum problem
  • Thread starter Thread starter erisedk
    Balls
In a problem involving two identical balls connected by a massless thread in gravity-free space, the correct conclusions are that the thread becomes taut at time t=L/v and remains taut thereafter. The discussion highlights the importance of understanding the motion of the balls, which involves both linear and angular momentum. Basic trigonometry and momentum conservation principles are essential for analyzing the system's behavior, particularly when the balls align in a straight line. The kinetic energy of the system does not remain constant at mv^2, as the final velocities after the interaction differ from the initial velocities. Overall, the analysis emphasizes the need for careful consideration of momentum conservation in both x and y directions.
erisedk
Two identical balls are interconnected with a massless and inextensible thread. The system is in gravity free space with the thread just taut. Each ball is imparted a velocity v, one towards the other ball and the other perpendicular to the first, at t=0. Then,
(A)The thread will become taut at t=L/v
(B)the thread will become taut at some time t<(L/v)
(C)The thread will always remain taut for t>(L/v)
(D)The kinetic energy of the system will always remain mv^2.
The correct options are (A) and (C).
m1u1 + m2u2 = m1v1 + m2v2
KE= 1/2 mv^2
There is no collision! How do I even start?
KE= 1/2 mv^2
Start by using some simple numbers for L and v and drawing a diagram of where the balls are after 1, 2 and 3 secs etc. e.g L = 3m and v = 1m/s.
That's not the problem. I get how the situation will look like when the string becomes taut. The string will form sort of a diagonal.
Maybe that's not correct. Maybe it isn't a sort of diagonal.
Oh ok. Then I don't know how they'll move. How do I draw a diagram at different instants of time? I don't know what their velocities are. I figured I could use momentum conservation and velocity of centre of mass to figure out their velocities, but I can't.
Some basic trigonometry shows that the string becomes loose when the balls start to move. If you map the constant motion of both balls you will see when the string becomes taut again. After that conservation of momentum will be very important to see what happens.
I tried mapping it out. I think the string will become taut when the two balls lie in a straight line, one above the other. The time taken to get there will be L/v, as the ball with the horizontal acceleration has velocity v. So at t=L/v, it becomes taut, and I'm pretty sure it'll stay that way. However, how do I conserve momentum in order to figure out the velocities of the two particles?
Remember that momentum is conserved in each direction.
It may help to take the initial motion of one of the balls as the frame of reference.
When the string becomes taut again, that is a kind of collision.
So I used conservation of momentum along x and y directions, assuming that after the "collision " both the balls move with the same velocities in both x and y directions. So final velocity of each ball in x and y directions is v/2 so the resultant final velocity of each ball is v/root 2 , so the final kinetic energy is 2(1/2mv^2/2) which is clearly not equal to mv^2. Hence option (d) is incorrect. Thank you PeroK and haruspex :)
But they won't; the system will have angular momentum.
  • · Replies 17 ·
  • · Replies 24 ·
  • · Replies 18 ·
