Band Dispersion and Career Mobility
6 replies · 5K views · last reply
arvind
how the dispersion relation(i.e. E-k relation) affects carrier mobility in metals or semi-metals?
I'm not sure if you have done any search on your own. You would have discovered the answer yourself.
For example, the electron mobility can be written, in the simplest form, as
[tex]\mu = e\tau/m^*[/tex]
where μ is the mobility, τ is the scattering time, e is the charge, and m* is the effective mass. Now, look up the relationship between the effective mass and the band dispersion, and you have your answer.
Zz.
what if the charge carriers are massless as in case of graphene which is a single atom thick sheet?
In general, the velocity of a wavepacket describing the motion of a particle is given as ##\partial E/\partial k##. You can now figure out what happens for a quadratic and a linear dispersion relation.
The book by Ashcroft and Mermin discusses all this in detail.
Zz.
Is there a simple and convenient way to estimate the electron mobility ?
I can derive the [itex]m^*[/itex] from band structure data ( through curve-fitting and then take a derivative with respect to k-point),but I know little information for the scattering time ;how to estimate [itex]\tau[/itex] for the systems (for example, BN sheet,or phosphorus) ?
There is also another formula ,i.e.,
[tex]\upsilon_{d}=μE[/tex]
it seems not cowork with those data using first princple softwares.
Not really, it depends on the scattering mechanism, e.g. impurity scattering or scattering from phonons. The latter should be most relevant in very pure samples. To quantify it ab initio, you would have to calculate the phonon spectrum and electron phonon coupling constants.
Thank you for your suggestions.
But I find some vitual frequency when use phononpy and vasp to calculate the phonon of black phosphorus nanotubes (about 32 atoms for armchair PNT with n=8,see the figure below).On the other hand,it is very time consuming when use Elk-code (about 5 days for 4 atoms,which use DFPT method).
Are there any convienient phonon softwares or programs for nanotubes ?
Phonon band structure plot with frequency on the vertical axis from -2 to 16 and wave vector on the horizontal axis, showing many blue dispersion curves, with several dipping slightly below zero near the low-frequency end.
