Basic electrostatics problem; analytical solution?
5 replies · 2K views · last reply
Taulant Sholla
Diagram of two identical pendulums hanging from a common point, each with a string of length L and a sphere labelled q, M; the left string makes angle θ with the vertical.
For the system given, both objects have the same charge and same mass (both given). I'm also given string length, L. I need to solve for θ.
Coulomb's Law, W=mg
Using simple equilibrium force analysis (with weight, tension, and electrostatics forces), I get:
Equation written as sin cubed theta over cos theta equals k q squared over 4 L squared m g, with the numerator and denominator stacked as a fraction.
Is there a way to solve for θ analytically, or do I have to find a graphical solution?
Thank you!
It might be manipulated into the form of a cubic equation. Cubics have a closed form solution for their roots. It'll involve a couple of changes of variables I think. Try expressing cos(θ) in terms of sin(θ), and then call x = sin(θ) so you're working with x rather than trig.
Coulomb's Law, W=mg
Thank you!
The equation ##\sin^3(\theta)/\cos(\theta) = a## is not difficult to solve analytically. For ##a > 0## we have ##0 < \theta < \pi/2##, so ##\cos(\theta) = \sqrt{1 - \sin^2(\theta)} > 0##. Therefore, the new variable ##x = \sin^2(\theta)## obeys the cubic equation ##x^3/(1-x) = a^2##. The exact solution of this cubic is not too complicated or difficult to work with. From ##x## we can recover ##\theta = \arcsin(\sqrt{x})##.
I get that
sin(θ) cos(θ) = kq2/4L2mg
which, if correct, then comes to
½ sin(2θ) = kq2/4L2mg
I believe this is incorrect. I'm pretty sure of the solution I posted, since it does agree with computational results.
Thank you so much!
I went down this path and saw the enormously complexity of solving cubics, which is - I guess - why we're taught to use graphical solutions methods instead.
