bksree
- 75
- 3
Basic question on induced emf - ATTACHMENT CORRECTED PLEASE RE-READ
Hi
Please read the attached doc which is excerpted from the text University Physics by Young & Freedman.The discussion is on the emf induced in a loop made of a superconducting material when a magnet is moved towards it.
Doubt 1
It is stated that 'the flux through the loop is exactly the same as it was before the magnet started to move'
Before the magnet moved the flux was downwards and due to the magnet. Once the magnet is moving emf is induced in the coil opposing the motion; so in this case the coil current is CW looking from above and the coil field now opposes the magnet field. Since the coil resistance is zero (superconductor) the current flows even after the magnet is stopped and so the net field after the magnet is stopped is the difference between the downward and upward fields which is NOT the same as the field before motion.
Doubt 2
It is stated that 'so the flux through a loop of zero resistance never changes'
In the above case the flux after motion is the difference between the downward and upward fields which is NOT the same as the field before motion (wherein the flux was downward).
Doubt 3
Is it possible (by adjusting coil radius and magnet motion) to have high current through the wire and net flux (coil flux due to induced current minus magnet flux)upward after motion
TIA
Hi
Doubt 1
Doubt 2
Doubt 3
TIA
