What is the speed of the ball after colliding with a bat at 1.7 m/s?
  • Thread starter Thread starter Rasine
    Ball Collison
The discussion centers on calculating the speed of a ball after colliding with a bat, both initially traveling at 1.7 m/s. Given the assumption of a perfectly elastic collision and that the bat's mass is significantly larger than the ball's, the conservation of momentum and kinetic energy principles apply. The relevant equations include the conservation of momentum (v1i + v2i = v1f + v2f) and kinetic energy equations. The final speed of the ball after the collision can be determined by treating the bat as stationary and applying these principles.
  • Understanding of elastic collisions
  • Knowledge of conservation of momentum
  • Familiarity with kinetic energy equations
  • Basic physics concepts related to velocity and mass
  • Study the principles of elastic collisions in detail
  • Learn how to apply conservation of momentum in collision scenarios
  • Explore the relationship between mass and velocity in elastic collisions
  • Investigate frame of reference changes in collision analysis
Physics students, educators, and anyone interested in understanding the dynamics of collisions in mechanics.
Rasine
A ball and bat, approaching one another each with the same speed of 1.7 m/s, collide. Find the speed of the ball after the collision. (Assume the mass of the bat is very much larger than the mass of the ball, a perfectly elastic collision, and no rotational motion).
so i am going to use of energy, and since it is an elatic collison, it will be kenitic energy
.5m1v1i^2+.5m2v2i^2=.5m1v1f^2+.5m2v2f^2
since the mass of the bat is much larger than that of the ball, i am going going to use
v1i+v2i=v1f+v2f
so, if the bat and ball are approching each other at the same speed i am going to take the ball approching the bat to be negitive, so i have
1.7-1.7=v1f+v2f
the answer isn't 0...so this is where i am stuck
v1i+v2i=v1f+v2f
Could you explain this assumption please?
i really don't know! i was just trying to go somewhere...can you help me?
Does this mean that the collision can be treated like a 'ball vs. wall' collision?
i don't know...but i was also thinking that the bat would be taken as 0 and the velociyt of the ball could be 2(1.7)
congrats, radou. Seems like everyone's turning gold around here! :approve: (I know your thinking; you just want more medals! :-p)
(sorry for the OT comment Rasine)
Actually, you are on the right track with this thinking. More precisely: In a frame in which the bat is at rest, the ball moves with speed 2x(1.7). In that frame, treating the bat as hugely massive, what's the rebound velocity of the ball? Then convert back to the original frame to find the ball's speed with respect to the ground.
Just to add, if you assume m2 >> m1, (where m2 is the mass of the bat), you can easily verify your result by simply using conservation of momentum, unless I'm missing something here.
Bingo. :biggrin:
so if i do that ussing conseravation of energy i will have
0+m2(2*1.7)=0+m2(2*1.7)...right?
i am so confused
  • · Replies 17 ·
