Answer: Battery Driven Winch - 13.5 m Lift Height
The discussion focuses on the performance of standard and alkaline D cell batteries when used to power a winch with a 13.5-meter lift height. A standard D cell can lift a 60 kg mass to this height while dissipating energy at different rates due to internal resistance, which is 1 ohm for the standard cell and 0.1 ohm for the alkaline cell. Calculations reveal that the maximum lift speed for the standard D cell is 0.1875 cm/s, while the alkaline D cell achieves 1.1875 cm/s. Both batteries ultimately allow for a total lift height of 13.5 meters before depletion.
  • Understanding of electrical power calculations (P=I*V)
  • Knowledge of gravitational potential energy (U=mgh)
  • Familiarity with internal resistance in batteries
  • Concept of efficiency in mechanical systems
  • Explore the Maximum Power Transfer Theorem in electrical circuits
  • Learn about battery chemistry and its impact on performance
  • Investigate the effects of load resistance on battery output voltage
  • Study efficiency optimization in electric motors and winches
Engineers, physics students, and hobbyists interested in battery-powered systems, particularly those working with winches or similar mechanical devices.
RyanP
A standard D cell can supply 10mA at 1.5 volts for about 300 hours. An alkaline D cell can do about the same. Assume - 2 - that the chemistry of the batteries will produce the same amount of energy and will maintain the same EMF regardless of the current drawn from the battery. However, the internal resistance of a standard D cell is about 1 ohm and the internal resistance of an alkaline cell is about 0.1 ohm, so the amount of energy dissipated internally is different. Let us suppose that you have a multi-speed winch that is 50% efficient and that your mass is 60kg.
(a) If the winch is set to super-slow speed how high can one of these batteries lift you before it is exhausted?
(b) What is the fastest rate (in cm/sec) that each battery can lift you?
(c) At this fastest lift rate, what is the maximum height that you achieve before the battery dies? How long does it take?
P=I*V=W/t
U(gravity)=mgh
[/B]
a). I said power dissipated here = 1.5V*10mA = 0.015 W.
50% efficiency means 0.0075 W are used by the winch. 0.0075 * (3600 s/hr * 300 hr) = 8100 J supplied by the battery. Weight = 60 kg * 10 m/s^2 = 600 N, so total distance traveled = 8100/600 = 13.5 meters.
b.) For a standard D cell,
- maximum current draw = 1.5V/(R_internal) = 1.5 A. Power dissipated = 1.5 V * 1.5 A = 2.25 W. At 50% efficiency 1.125 W are used by the winch.
- Power = Energy / time. P=mg(delta(h)/delta(t))
1.125 W = 60kg * 10m/s^2 * (h/t), so h/t = speed = 0.1875 cm/s.
For an alkaline D cell,
same as above but multiplied by a factor of 10 = 1.1875 cm/s.
c.) Total energy supplied by the battery over its lifetime = 0.01A*1.5V*(300 hr * 3600 s/hr) = 16,200 J.
Time = Energy/power. For a standard D cell, t = 16,200 J / (2.25 J/s) = 7,200 s.
For an alkaline D cell, t = 16,200 / 22.5 = 720 s.
Total distance traveled = speed * time = 0.1875 cm/s * 7200 s = 13.5 m total.
Perhaps check answer b. What is the voltage delivered to the winch if 1.5A is being drawn? It's not 1.5 V. Would a lower current deliver a higher voltage and more power?
Doesn't the voltage delivered by the battery remain constant? As in, "the chemistry of the batteries will produce the same amount of energy and will maintain the same EMF regardless of the current drawn from the battery."
Reference https://www.physicsforums.com/threads/battery-driven-winch.889785/#post-5597336
Nope. The internal EMF remains the same but the battery's internal resistance lies between the source of the EMF and the battery terminals. In other words, a real battery is modeled as an ideal voltage source in series with a resistance.
How could I figure out the voltage across the winch without knowing its resistance?
The questions are posed in such a way that you're looking for extreme situations. One thing I'd advise reviewing is the Maximum Power Transfer Theorem :wink:
The winch will draw a current that depends on it's load. You can show that the output of the battery will be somewhere between 0A @ 1.5V and 1.5A @ 0V.
Try picking some values of the current (say 0A, 0.5, 0.75, 1, 1.25 1.5A ) and calculate the output voltage and then output power. Then sketch two graphs of output power vs current and Output power vs Voltage. Where is the power a maximum?
Once you "see the light" you may not have to plot the graphs next time.
I tried the max power transfer theorem and revised parts (b) and (c) (I don't think part a changes since it's just an energy calculation):
b. Max power: R_internal = R_load.
For a standard D cell, R_load = 1 ohm. Power dissipated by the load = I^2 * R_load = R_load * ([V_source] / [R_int+R_load])^2. If V=1.5V and both R's = 1 ohm, Power = 0.5625 W.
At 50% efficiency, P = 0.281 W = mg(h/t). Thus h/t = 0.047 cm/s.
For an alkaline D cell, same as above but with R_int = R_load = 0.1 ohm, which leads to v = 0.47 cm/s.
c. Dividing total energy by power dissipated in the load: 16200J / 0.5625 J/s = 28800s for standard D cell, and 2880 s for alkaline. Running at their respective speeds, both batteries give the same result for total height, 13.5 m. Does this sound right? Or do I need to divide energy by 2*power to account for power dissipation in the battery itself?
