Bayes' theorem and disease prevalence
12 replies · 2K views · last reply
BRN
Claculate prevalence, sensitivity and specificity of the diagnostic test.
Bayes theorem
Hello at all!
I have to solve this exercise:
A tampon diagnostic test provides 1% positive results. The positive predictive values (probabilities of positive test disease) and negative (absence disease given negative test) are respectively 0.95 and 0.98.
  1. What is the prevalence of the disease?
  2. What are the sensitivity (probabilities of positive disease with disease) and specificity (negative test probability with disease absence) of the test?
With positive test (T+), negative test (T-), disease (D) and healthy (D-), I have this table:
DD-
T+P(T+|D)P(T+|D-)
T-P(T-|D)P(T-|D-)
## P(D|T+) = 0.95 ##, ## P(D-|T-) = 0.98 ## and ## P(T+) = 0.001 ##.
From Bayes theorem I can calculate sensitivity starting from:
$$ P(D|T+) = \frac{P(T+|D)P(D)}{P(T+)} $$
But how can I calculate the prevalence ## P(D) ##?
I hope I understand the terminology here. I assume this means that if someone has the disease then there is a 0.95 probability of a positive result (and hence a 0.05 probability of a false negative). And, if someone does not have the disease, then there is a 0.98 probability of a negative results (and a 0.02 probability of a false positive). And, I guess the prevalence means how many people have the disease.
What you could do is assume that the prevalence is ##P(D) = p##, calculate the positive results (as a function of ##p##) and equate this to 1%.
PS Although that makes no sense, as with a false positive of 0.02, you must get at least 2% positive tests, even if no one has the disease. Perhaps I've misunderstood the terminology?
PPS I did misunderstand!
Your post seems a bit garbled. Do you mean
BRN said:
A tampon diagnostic test provides 1% positive results. The positive predictive values (probabilities of disease given positive test ) and negative (absence disease given negative test) are respectively 0.95 and 0.98.
  2. What are the sensitivity (probabilities of positive test given disease) and specificity (negative test probability with disease absence) of the test?
So it's not Bayes' Theorem you need.
What is the relationship between P(A), P(A|B) and P(A|~B)?
haruspex said:
Your post seems a bit garbled. Do you meanSo it's not Bayes' Theorem you need.
How could you get 1% positive tests with a 2% false positive rate? That's how I read the question.
No, it's a false negative rate of 2%. P(absence of disease given negative test)=0.98.
This is interesting. The sensistivity and specificity you are asked to find are related to False Positive and False Negatives:
https://en.wikipedia.org/wiki/Sensitivity_and_specificity
To be precise:
True Positive (Sensitivity) = probability/proportion of positive test results for those who are positive (have the disease)
False Negative = (probability of) negative test for those who are positive
True Negative (Specificity) = probability/proportion of negative test results for those who are negative (do not have the disease)
False Positive = (probability of) positive test for those who are negative
The values we are given is:
Positive Predictive Value: probability that a person is positive given a positive result
Negative Predictive Value: probability that a person is negative given a negative result
https://en.wikipedia.org/wiki/Positive_and_negative_predictive_values
That seems to be the standard terminology.
Thanks for your help.
To be precise:
OK, the terminology seems right.
So I have:
P(D|T+) = 0.95 Positive Predictive Value
P(D|T-) = 0.05
P(D-|T-) = 0.98 Negative Predictive Value
P(D-|T+) = 0.02
P(T+) = 0.01 positive results
P(T-) = 0.99
and I won't to calculate:
P(D) = prevalence
P(T+|D) = Sensitivity
P(T-|D-) = Specificity
PeroK said:
What you could do is assume that the prevalence is , calculate the positive results (as a function of ) and equate this to 1%.
I try to do this:
from Bayes theorem I have
$$ P(D|T+) = \frac{P(T+|D)P(D)}{P(T+)} \Rightarrow P(T+|D)P(D)=P(D|T+)P(T+) $$
Now
$$ P(T+) = P(T+|D)P(D) + P(T+|D-)(1-P(D) $$
$$ \Rightarrow P(T+) = P(D|T+)P(T+) + P(T+|D-)(1-P(D) $$
$$ \Rightarrow P(T+) -P(D|T+)P(T+) = P(T+|D-)(1-P(D) $$
$$ \Rightarrow P(T+) (1-P(D|T+)) = P(T+|D-)(1-P(D) = FP$$
FP = False Positive.
Now I wouldn't know how to continue...
So I have:
P(D|T-) = 0.05
P(D-|T+) = 0.02
P(T-) = 0.99
P(D) = prevalence
I try to do this:
Now
Please try to answer my question in post #3.
BRN said:
So I have:
P(D|T-) = 0.05
P(D-|T+) = 0.02
P(T-) = 0.99
That's doesn't look right. You must have ##P(D|T+) + P(D-|T+) = 1## etc.
P(D) = prevalence
Now
Okay, so you're going round in circles perhaps.
I find it's always easier to work from a probability tree, which gives a better insight than Bayes' Theorem (although it's the same information).
Using the tree method, the prevalance (##D_+##) falls out without any effort. The other quantities of sensitivity and specificity you can practically just read off as well.
Finding P(D) from the given data is very simple and does not require Bayes' Theorem. See post #3,
PeroK said:
Using the tree method, the prevalance () falls out without any effort. The other quantities of sensitivity and specificity you can practically just read off as well.
## P(T+) (PPV) + P(T+) (1-PPV) ## I can interpret it as the total number of positive tests observed (number of positive tests relating to the sick + number of positive tests related to healthy), right?
PeroK said:
That's doesn't look right. You must have etc.
Yes! I agree. I made a mistake...
But isn't there a single relationship, or am I wrong?
$$ P(A|B) = \frac{P(A \cap B)}{P(B)} $$
$$ P(A|\tilde B) = \frac{P(A \cap \tilde B)}{1-P(B)} $$
I'm sorry, but I'm a beginner...
Yes: $$P(T+) (PPV) + P(T+) (1-PPV) = P(T+)$$
I'm going to suggest you learn the probability tree method. These numbers are all related to each other and the best way to see this is a simple probability tree. The answers drop out (like ripe fruit, as it were!).
Did you understand the diagram I posted above?
Sorry, the way I expressed it wasn't very clear. It's easier via joint probabilities:
Can you express P(A) in terms of P(A∩B) and P(A∩~B)?
Then P(A∩B) in terms of P(A|B) and P(B) etc?
Wrt post #1, it probably would have been more helpful to have drawn a table of joint probabilities rather than of conditional probabilities. You could fill in four unknowns for these, a, b, c, d, then write expressions for the given data in terms of them. You would have got four equations.
