Solving the Rotating Wire Problem
The discussion focuses on solving the Rotating Wire Problem involving a circular wire hoop that rotates with a constant angular velocity, denoted as !, about a vertical diameter. The equilibrium position of a bead moving along the hoop is determined using Lagrangian mechanics, where the Lagrangian is defined as L = T - U, with T representing kinetic energy and U potential energy. The equation of motion derived is ## \ddot \theta = \frac g R \sin {\theta} + \sin {\theta}~ \cos { \theta}~{ \dot \phi}^2 ##, leading to the equilibrium angle calculated as ## \theta_0 = \arccos(-g/(\omega^2 R)) ##. The discussion concludes with a recommendation to rewrite the equation in terms of small angular departures to analyze small oscillations about the equilibrium position.
  • Understanding of Lagrangian mechanics and equations of motion
  • Familiarity with spherical coordinate systems
  • Knowledge of angular velocity and its implications in rotational dynamics
  • Basic concepts of harmonic oscillators and small oscillation analysis
  • Explore the derivation of Lagrangian mechanics in detail
  • Study the behavior of small oscillations in mechanical systems
  • Learn about the stability of equilibrium positions in rotating systems
  • Investigate the implications of angular velocity on potential energy in rotating frames
Students and professionals in physics, particularly those studying dynamics and rotational motion, as well as educators looking for practical examples of Lagrangian mechanics in action.
Pushoam
A circular wire hoop rotates with constant angular velocity ! about a vertical diameter. A small bead moves, without friction, along the hoop. Find the equilibrium position of the particle and calculate the frequency of small oscillations about this position.
Let's take our reference inertial frame as a spherical co-ordinate system whose axis is along the axis of rotation of the who and whose origin is at the centre of the hoop.
Then position of M can be given by r, ## \theta, \phi ##.
Constraint: r= R,
## \dot \phi = \omega ## , constant.
There are two generalised coordinates ## \phi ## and ## \theta ##.
L = T - U
## T = \frac 1 2 mR^2 ( {\dot \theta}^2 + \sin ^2 \theta {\dot \phi}^2) ##
Taking U = 0 at the origin, U = mgR ## \cos \theta ##
So, L = ## \frac 1 2 mR^2 ( {\dot \theta}^2 + \sin ^2 \theta {\dot \phi}^2 ) - mgR ## ## \cos \theta ##
Lagrange's equation of motion gives,
At eqbm. ## \ddot \theta = 0 ##
## \theta = 0, \Pi , \cos {\theta} = \frac {-g} { \omega^2 R} ##
What to do next?
Pushoam said:
What to do next?
Rewrite your equation of motion in terms of a small angular departure from equilibrium and see if you can bring the equation into the form of a harmonic oscillator.
Let ##\theta \rightarrow \theta_0+\alpha##, where ##\theta_0 = \arccos(-g/(\omega^2 R))## and expand the EOM for small values of ##\alpha##. Don't forget that ##\sin \theta \cos \theta = \sin(2\theta)/2##.
Where are you measuring ##\theta## from? If ##\theta=0## is supposed to be when the bead is at the bottom of the loop, then the sign of ##U## is wrong.
It all makes sense if ##\theta## is measured from the top. Then the equilibrium angle is (as it should) below the horizontal diameter and its cosine is negative. U is zero when ##\theta = \pi/2##.
Yeah, I know. It's just that most people use the convention that ##\theta=0## is the (stable) equilibrium position when the hoop isn't spinning. Thought it was worth making sure.
I solved it. Thank you all for the guidance.
