What is the required load to bend a steel plate in a radius of 508mm?
  • Thread starter Thread starter swapnasis
    Bending Load
The discussion centers on calculating the load required to bend a steel plate with specific dimensions and conditions. The steel plate is 2000mm wide, 25mm thick, and is supported by two steel rollers of 180mm diameter. A third roller applies force at the center to achieve a bending radius of 508mm. Participants emphasize that traditional beam bending formulas may not yield accurate results due to large deflections and potential local plastic deformation of the material, particularly if mild steel (M.S.) is used. For accurate calculations, users are directed to consider the bending of simply supported thin plates under point loads and to reference resources like Timoshenko's "Theory of Thin Plates."
  • Understanding of beam bending formulas and their limitations
  • Familiarity with material properties, specifically mild steel (M.S.)
  • Knowledge of stress and strain concepts in materials
  • Basic principles of mechanics of materials, particularly for thin plates
  • Research "bending of simply supported thin plates under point load" for detailed methodologies
  • Study "Theory of Thin Plates" by Timoshenko for foundational concepts
  • Explore online calculators for bending loads on plates, such as those on eFunda
  • Learn about the impact of local plastic deformation on bending calculations
Mechanical engineers, structural engineers, and students involved in projects related to material deformation and load calculations for bending steel plates.
swapnasis
Hi...
I am doing a project to calculate the load required to bend a plate.. Here are the details..
There is steel plate of 2000mm width and 25mm thcikness placed over 02 support steel rollers of diameter 180mm. Another steel roller of same diameter press from the top of the plate at the center of the bottom support rollers. How much load is required to bend the plate in a radius of 508mm?
I was calculating the above with the help of beam bending formula. Means one bean placed on top of 02 support beams and load is given at the center of the beam for bending. But I didn't get the answer perfectly.
Can somebody help me to find out the solution?
Swap..
Hi swapnasis.
Your approach is quite right. But the beam deflection formula is applied for only small deflections. But in your case deflection is quite large and hence you cannot rely on the accuracy of the results. Moreover if the steel used is M.S. then local plastic deformation of the plate at the center roller will lead to more inaccuracy of the result.
koolraj09 said:
Hi swapnasis.
Thanks KOOLRAJ for your reply. But still I am confused about the formula and answer.. Can you please help me showing me the calculations with the beam bending formula? Atleast I can reach near to the exact solution..
Hi again.
Stress in large bending deformation:
For large deformations of the body, the stress in the cross-section is calculated using an extended version of this formula. First the following assumptions must be made:
1. Assumption of flat sections - before and after deformation the considered section of body remains flat (i.e. is not swirled).
2. Shear and normal stresses in this section that are perpendicular to the normal vector of cross section have no influence on normal stresses that are parallel to this section.
Large bending considerations should be implemented when the bending radius ρ is smaller than ten section heights h:
ρ < 10h
With those assumptions the stress in large bending is calculated as:
F is the normal force
A is the section area
M is the bending moment
ρ is the local bending radius (the radius of bending at the current section)
Ix' is the area moment of inertia along the x axis, at the y place (see Steiner's theorem)
y is the position along y-axis on the section area in which the stress σ is calculated
For more info visit http://en.wikipedia.org/wiki/Bending
Hi...
Thanks again. I got your reply. But still it is confusing. I don't need to calculate the stress in the cross section. I need to calculate the load(Bending force) to bend the cross section on such condition. How much exact load(bending force) we require to bend the cross section of the said dimension as I have mentioned earlier?
Hope to get the reply soon..
koolraj09 said:
Hi again.
ρ < 10h
Hi...
Thanks again for the reply. But still it is confusing. I am not calculating the stress in the cross section. I want to know the required load(Force) to bend the cross section. I am again indicating the details..
There is a steel plate(YS= 80,000Psi) of 2000mm width, 2000mm long and 25mm thickness. The plate is supported at both end from the bottom with 02 steel rolls of 180mm diameter. To bend the steel plate with a radius of 508mm, another steel roll of 180mm diameter is presses from the top of the plate at the center. Now the question is how much load(force) is required to bend the steel plate to achieve the required radius? It is really not a beam but a steel plate which is to be bent for a vessel.
Please give me the reply if you can solve the problem.
Thanks again for giving me the time..
koolraj09 said:
Hi again.
ρ < 10h
hey swap .. I read thru ur problem very fast .. I got not much time .. As far as I understood u have to find the load which causes a displacement of 508mm. I would suggest go thru the bending of Simply supported thin plates under point load. I am sending a link as well. I am sure this will help u. Sorry can't solve the prob for u as i am kinda bz .. but this shud help u for sure ... Njoi and best o luck :)
http://www.efunda.com/formulae/solid_mechanics/plates/casestudy_list.cfm
http://www.efunda.com/formulae/solid_mechanics/plates/calculators/SSSS_PPoint.cfm
or els u can read Theory of thin plates by timoshenko .. Find the equation for displacement in the plate due to applied load. u know the end conditions ... U know the displacement and u can find the Load required .. Best o luck ..
hiii...swapnasis
I am also doing a project to calculate the load required to bend a plate.. Here are the details..
There is steel plate of 1600mm width and 12mm thcikness for three roller bending machine now i want to calculate rolls diameter and bending radius of plate can u help me?
I want formulas to calculate it..
hii swap i am also doing the same project can u pls tell me the formulas for bending plate
