Bending stiffness of circular bars
The bending stiffness of a circular rod and a circular rod surrounded by a tube are equal when analyzed through their second moments of area. The calculations confirm that the effective stiffness remains the same due to coincident neutral axes, which prevents relative motion between the rod and the tube. This conclusion is supported by the mathematical derivation of the second moments of area for both configurations, indicating that the stiffness does not change despite the presence of the tube.
  • Understanding of second moments of area in structural engineering
  • Knowledge of bending stiffness calculations
  • Familiarity with the concept of neutral axis in beam theory
  • Basic principles of cantilever and simply supported beams
  • Study the derivation of second moments of area for various cross-sections
  • Learn about the implications of neutral axis positioning in composite beams
  • Explore the differences in bending stiffness between bonded and unbonded structures
  • Investigate the behavior of cantilever beams under point loads
Structural engineers, mechanical engineers, and students studying mechanics of materials who are interested in understanding bending stiffness and beam behavior in composite structures.
itsmi
Which of the two is stiffer in bending?
1. A circular rod of diameter D and length L.
2. A circular rod of diameter d and length L, surrounded by a tube of inner diameter d, outer diameter D, and length L. The tube is not bonded and can freely move.
It seems like an easy solution in that we only need to calculate the second moments of area, which yields the same stiffness for both cases. However, I've had a hard time convincing people of this and would like to confirm that the bending stiffnesses are, indeed, equal. Thank you!
The effective stiffness will not be the same for the two cases .
Note these words in the problem statement " The tube is not bonded and can freely move "
What does that tell you ?
Thank you for the quick response.
I'm aware that this is the tricky part. But the question is: Will it move (relatively to the rod)? I don't think it will. How would you approach this problem mathematically, rather than using your intuition?
The problem statement says that the tube is not bonded and can freely move ?
Ok, so here's my procedure
  • I: Second moments of area, which directly relate to the stiffness
  • R: Radius of big rod and outer radius of tube
  • r: radius of small rod and inner radius of tube
ROD
IbigRod = pi/4*R4
ROD + SHELL
IRodAndTube = IsmallRod + Ishell = pi/4*r4 + pi/4*(R4-r4) = pi/4*R4
Hence:
IbigRod = IRodAndTube
Note: The neutral axis remains at the same position in both cases, not like in the typical example where you place many thin plates on top of each other and compare it to one thick plate of the same total thickness.
Where do you think the mistake is and which theory/law makes you think that?
Anyone else?
Just try solving for the stiffness of a simple cantilever with point load at the end .
If you do the analysis properly you will get different answers for the two beams
You keep saying it is different, but you still haven't given any explanation or good reason, despite me asking multiple times. As I said, I did the calculation and get the same results. It doesn't matter if it's a three point bending or cantilever beam with a point load.
Is there anyone else who can give me an explanation for whichever solution is correct?
itsmi: Your answer is correct. The second moments of area of the two cases are equal. The reason is as explained by you. I.e., as you alluded to, the neutral axes of the individual components are coincident. Therefore, there is no relative motion between the telescoped parts.
Consider a simply supported beam with point load at mid span . With the point load acting on the outside of the tube what load acts on the central bar ?
  • · Replies 22 ·
