Bending stiffness of circular bars
The discussion centers on the bending stiffness of two configurations of circular rods: one being a solid circular rod and the other a circular rod surrounded by a non-bonded tube. Participants explore the implications of the tube's ability to move freely and how this affects the overall stiffness calculations.
  • One participant suggests that the bending stiffness of both configurations is equal based on the calculation of second moments of area.
  • Another participant argues that the effective stiffness will not be the same due to the tube's ability to move freely, implying potential relative motion between the rod and the tube.
  • A different participant questions whether the tube will actually move relative to the rod, seeking a mathematical approach to the problem rather than relying on intuition.
  • One participant presents a detailed calculation of the second moments of area for both configurations, asserting that they are equal and questioning where the mistake might be in the opposing argument.
  • Another participant suggests analyzing a simple cantilever beam with a point load to demonstrate that the stiffness will differ for the two configurations.
  • A later reply supports the initial claim that the second moments of area are equal, citing coincident neutral axes as a reason for no relative motion between the components.
  • One participant introduces a scenario involving a simply supported beam with a point load to question the load distribution between the tube and the central rod.
Participants express disagreement regarding the bending stiffness of the two configurations, with some asserting they are equal and others arguing they are not. The discussion remains unresolved, with multiple competing views presented.
Participants reference the importance of the tube's movement and the implications for stiffness calculations, but there are unresolved assumptions regarding the behavior of the system under load and the conditions of support.
itsmi
Which of the two is stiffer in bending?
1. A circular rod of diameter D and length L.
2. A circular rod of diameter d and length L, surrounded by a tube of inner diameter d, outer diameter D, and length L. The tube is not bonded and can freely move.
It seems like an easy solution in that we only need to calculate the second moments of area, which yields the same stiffness for both cases. However, I've had a hard time convincing people of this and would like to confirm that the bending stiffnesses are, indeed, equal. Thank you!
The effective stiffness will not be the same for the two cases .
Note these words in the problem statement " The tube is not bonded and can freely move "
What does that tell you ?
Thank you for the quick response.
I'm aware that this is the tricky part. But the question is: Will it move (relatively to the rod)? I don't think it will. How would you approach this problem mathematically, rather than using your intuition?
The problem statement says that the tube is not bonded and can freely move ?
Ok, so here's my procedure
  • I: Second moments of area, which directly relate to the stiffness
  • R: Radius of big rod and outer radius of tube
  • r: radius of small rod and inner radius of tube
ROD
IbigRod = pi/4*R4
ROD + SHELL
IRodAndTube = IsmallRod + Ishell = pi/4*r4 + pi/4*(R4-r4) = pi/4*R4
Hence:
IbigRod = IRodAndTube
Note: The neutral axis remains at the same position in both cases, not like in the typical example where you place many thin plates on top of each other and compare it to one thick plate of the same total thickness.
Where do you think the mistake is and which theory/law makes you think that?
Anyone else?
Just try solving for the stiffness of a simple cantilever with point load at the end .
If you do the analysis properly you will get different answers for the two beams
You keep saying it is different, but you still haven't given any explanation or good reason, despite me asking multiple times. As I said, I did the calculation and get the same results. It doesn't matter if it's a three point bending or cantilever beam with a point load.
Is there anyone else who can give me an explanation for whichever solution is correct?
itsmi: Your answer is correct. The second moments of area of the two cases are equal. The reason is as explained by you. I.e., as you alluded to, the neutral axes of the individual components are coincident. Therefore, there is no relative motion between the telescoped parts.
Consider a simply supported beam with point load at mid span . With the point load acting on the outside of the tube what load acts on the central bar ?
  • · Replies 22 ·
