So let me continue missing the whole point by introducing another method called Method-6. In this method, the orientation is similar to method-2 in which a point is chosen on the radius and a cord is constructed to be perpendicular to the radius. To calculate the probability of chord longer than the side of the triangle, we follow the chord until it meets with the circle circumference and then calculate the length of the arc, which represent all chord longer than the triangle side, from the point on the circle where the diameter ends to the point on the circle where a parallel line to the diameter and to the side of the triangle that is bisecting radius also meets with the circumference. It is not surprising to see that the length of the first arc=1/2 the second one which means the probability of chords longer than the triangle length is 1/3 which is equivalent to the result of Method-1
This means if we had to use the length of the arc rather than the length on a diameter in method-2, we would have ended to the exact same result of method-1, namely the probability amount of 1/3. This also means that in order to have a non-paradoxical results, it is important to have standard definition during the calculation. If we used arc lengths in method-1 we should have not changed to parts of the diameter in method-2.
So missing the point by introducing more methods yielding the same probability would create no paradox, while sticking to the point would create a paradox. This means that sometimes it is important to missing the whole point in order to solve a paradox which is created by not missing any points. This itself may be a new "Missing Points Paradox".
