- 12,058
- 2,357
Building again on lavinia's posts, we know SO(3) is homeomorphic to RP^3, the real projective 3-space, which is a solid ball with antipodal points on each diameter identified. She has described how to see this as a union of a family of projective planes sharing a common circle, i.e. of a P^1 of projective planes, sharing a common P^1.
It is easy to see that P^3 has such a decomposition just from projective geometry. I.e. just take any (projective) line in projective 3-space and consider all (projective) planes containing that line. This sweeps out P^3 as a union of copies of P^2 having a common line, i.e. a common P^1 or circle.
P^2 also has a decomposition as a union of projective lines with a common point. Just take any point in your P^2 and consider all lines through that point. This P^1 of lines with a common point sweeps out P^2.
One can also see these decompositions directly in the group SO(3). I.e. given a sphere, fix an axis, say joining the north and south poles. Now choose any plane through that axis, and consider all rotations of the sphere with axis in that plane. This subset of SO(3) is naturally a copy of P^2. E.g. this set of rotations has a natural decomposition as a union of copies of P^1 each with a common point. I.e. for each axis in this plane, the rotations about such an axis forms a P^1, and they all share the identity rotation, so rotations with axis in a given plane, are a union of a circular family of P^1's, all with a common point. As we vary the given plane, we decompose SO(3) as the union of a P^1 of copies of P^2, all with a common P^1 or circle.
Indeed one can see directly the structure of SO(3) as P^3 as follows: we know P^3 is obtained from a solid ball of radius π by identifying antipodal points on each diameter. This space is directly homeomorphic to SO(3) as follows: the center of the ball is the identity rotation. On each radius, the point at distance t from the center represents the counterclockwise rotation about the head of that radius through t radians. Since the counterclockwise rotation about the head of radius vector v through π radians, is the same as the counterclockwise rotation about the head of radius -v through π radians, SO(3) is obtained in this way from the solid ball, by identifying antipodal points on each diameter, i.e. SO(3) is thus naturally identified with RP^3.
As above, the points lying on a given plane containing the north and south poles correspond to rotations with axis in that plane, hence to a copy of P^2, and SO(3) is the union of a "pencil" of, i.e. a P^1 of, these copies of P^2, parametrized by the P^1 of planes through the north-south axis.
