BigInt plus method with carryover for digit-by-digit addition
  • Topic: Comp Sci
  • Thread starter apiwowar
    Java
31 replies · 13K views · last reply
i changed my test code to what i posted below. it seems that the numbers go in right. num3.digit[47] is 1, num3.digit[48] is 0 and num3.digit[49] is 0 and everything before 47 is 0. but if i just print out num 3 it comes out as 001000...
Code:
import java.util.Scanner;
public class BigIntSimpleTestAlt
	public static void main(String[] args)
	Scanner input = new Scanner(System.in);
	//int number1 = input.nextInt();
	//int number2 = input.nextInt();
	BigIntAlternate num1 = new BigIntAlternate(99);
	BigIntAlternate num2 = new BigIntAlternate(1);
	BigIntAlternate num3 = new BigIntAlternate();
	num3 = num1.plus(num2);
	for(int i = 0; i <= 49; i++)
	System.out.println(i + " Num1 + Num2 = " + num3.digit[i]);
	System.out.println("\ncompare num1 and num2 " + num1.compareTo(num2));
So don't use print or println to display all of the digits. What you did by using a loop to go through each element in the digit array is fine.
Does this work?
Code:
System.out.print(num3.digit)
An even better solution would be to write print and println methods for your class to display the digit array.
The code would look like this:
Code:
// Display the digits of a BigNum object.
void print(BigNum bn)
   for (int i = 0; i < max; i++)
      print(bn.digit[i]);
The code for println would be almost identical, except that it would print a newline character after the last digit.
Your last code snippet is much improved, but could use two tweaks - all of the statements in the body of main should be indented, and the body of the for loop should be indented, like the following. I've deleted a few of the lines you aren't using.
Code:
