shaft system for a bevel gear reducer
  • Topic: Engineering
  • Thread starter jojosg
0 replies · 34 views
jojosg
The following figure shows a shaft system used in bevel-gear reducer. Given condition: mean diameter of pitch circle dm=30mm, Ft=1300N, Fr=400N, Fa=250N, n=14300r/min, af=1.5. please evaluate the bearing lifespan, where the bearing 30305 is used. Please also give explain the meaning of bearing designation 30305. (For Bearing used C=43200N, e=0.37, if Fa/Fr < e, X = 1, Y = 0; if Fa/Fr > e, X=0.4, Y=1.6, Fi=Fr/(2Y))
Bearing designation definition: 30305
[tex]
\text{3: Tapered roller bearing; 03: dimension series; 05: bore } d=5\times5=25\ \mathrm{mm}
[/tex]
Equivalent dynamic load:
[tex]
P = a_f\left(XF_r + YF_a\right)
[/tex]
Induced thrust:
[tex]
F_i = \frac{F_r}{2Y}
[/tex]
Bearing life in hours:
[tex]
L_{10,\mathrm{h}}=\frac{10^6}{60,n}\left(\frac{C}{P}\right)^p
[/tex]
For roller bearings, [itex]p=10/3[/itex].
I need to evaluate bearing life and explain the meaning of bearing designation 30305. I am not confident with my axial force balance step.
First, calculate resultant radial loads on bearing 1 and bearing 2.Vertical plane moment balance:[tex]F_{r2,v} = \frac{(F_t+F_r)\cdot 150}{100} = \frac{(1300+400)\cdot 150}{100}=2550\ \mathrm{N}[/tex][tex]F_{r1,v} = 1300+400 - 2550 = 850\ \mathrm{N}[/tex]
Horizontal plane, axial force creates bending moment [itex]M=F_a\cdot d_m/2 = 250 \times 15 = 3750\ \mathrm{N\cdot mm}[/itex][tex]F_{r2,h}=\frac{F_r\cdot 150 + 3750}{100}=637.5\ \mathrm{N}[/tex][tex]F_{r1,h}=|400 - 637.5|=237.5\ \mathrm{N}[/tex]
Resultant radial loads:[tex]F_{r1}=\sqrt{F_{r1,v}^2+F_{r1,h}^2}=\sqrt{850^2+237.5^2}=882.5\ \mathrm{N}[/tex][tex]F_{r2}=\sqrt{F_{r2,v}^2+F_{r2,h}^2}=\sqrt{2550^2+637.5^2}=2628.4\ \mathrm{N}[/tex]
Induced thrusts, using [itex]Y=1.6[/itex]:[tex]F_{i1}=\frac{F_{r1}}{2Y}=\frac{882.5}{2\times1.6}=275.78\ \mathrm{N}[/tex][tex]F_{i2}=\frac{F_{r2}}{2Y}=\frac{2628.4}{2\times1.6}=821.38\ \mathrm{N}[/tex]
Axial balance check:[itex]F_{i2}+F_a = 821.38 + 250 = 1071.38 > F_{i1}[/itex]So:[tex]F_{a1}=F_{i2}+F_a=1071.38\ \mathrm{N},\quad F_{a2}=F_{i2}=821.38\ \mathrm{N}[/tex]
Check ratios against [itex]e=0.37[/itex]:[tex]\frac{F_{a1}}{F_{r1}}=\frac{1071.38}{882.5}=1.214>0.37 \implies X_1=0.4,;Y_1=1.6[/tex][tex]\frac{F_{a2}}{F_{r2}}=\frac{821.38}{2628.4}=0.312<0.37 \implies X_2=1,;Y_2=0[/tex]
Equivalent loads:[tex]P_1 = a_f\left(X_1F_{r1}+Y_1F_{a1}\right)=1.5\left(0.4\times 882.5 + 1.6\times 1071.38\right)=3045.4\ \mathrm{N}[/tex][tex]P_2 = a_f\left(X_2F_{r2}+Y_2F_{a2}\right)=1.5\left(1\times 2628.4 + 0\right)=3942.6\ \mathrm{N}[/tex]Since [itex]P_2>P_2[/itex], Bearing 2 governs life.
[tex]L_{10,\mathrm{h}}=\frac{10^6}{60\times 14300}\left(\frac{43200}{3942.6}\right)^{10/3}[/tex]
My uncertainty:I’m not fully confident in the horizontal plane moment calculation from the bevel gear axial force, and also unsure whether my axial thrust balance direction is correct for this opposed tapered roller pair. Could you verify?
