Black Body Radiation Homework: Energy/Sec on 1m2 Earth from Sun
The discussion revolves around calculating the energy per second that falls on a 1 m² area of Earth from the Sun, based on the assumption that radiation travels radially outward without absorption. The problem involves concepts from black body radiation and the geometry of radiation spread over distance.
  • Participants explore the impact of distance on radiation intensity, questioning whether to consider the Sun's surface as flat or to account for the curvature of the Earth. There are discussions about calculating the surface area of a sphere at the Earth's distance and how to relate that to the power output of the Sun.
Some participants have provided calculations regarding the surface area of the sphere at the Earth's distance and the resulting power per unit area. There is a general agreement on the calculations presented, although explicit consensus on the final answer has not been established.
The problem assumes no absorption of radiation between the Sun and Earth and requires consideration of the geometry of radiation spread. The total power output of the Sun is given, along with the distance to Earth.
__JR__
Assume that the radiation emitted from the Sun moves radially outward from the Sun and that no radiation is absorbed between the Sun and Earth. How much energy in the form of radiation will fall per second on an area of 1 m2 on Earth, if that area is perpendicular to the straight-line path of the radiation? The distance from the Sun to Earth is 1.5e11 m. Assume the total power output of the sun is 4.47 x 1026 W.
Stefan Boltzmann formula - E(T) = \sigmaT4
Where I'm struggling is with the role the distance between the two bodies plays. Since the radiation is emitted radially outward, the distance between the two is relatively large, and the area on Earth is relatively small, does this mean I need to observe an infinitesimally small "window" on the surface of the sun whose radiated waves will strike this area on earth? Or, since the 1m2 on the curved surface of the Earth is relatively small I can assume that it, and a corresponding surface on the sun, is flat?
The power output of the sun can be determined by a surface temp of 6000K and a radius of 6.95x108 m (we solved this in an earlier problem).
At the distance of the Earth from the sun, the light is impinging on a spherical surface centered at the sun with the radius equal to the Earth's orbit. This surface area of this sphere is the area that the power is "spread" over.
Can you use this information to find the power per unit area at the Earth's distance from the sun? If so, the answer should then follow trivially.
Imagine the radiation leaving the sun as the surface of an expanding sphere, calculate the surface area of this sphere when it reaches the Earth's surface (i.e a sphere with a radius equal to the distance between the sun and the earth). By considering what proportion of the total surface area 1m^2 is, you can work out how much of the total power strikes that area.
Thanks for the replies, I think I've got the right answer.
So the total power output of the sun is 4.47e26 W, and the SA of the new sphere is 4*pi*(1.5e11)^2 m^2 = 2.82743e23 m^2.
Dividing gives 1580.94 w*m^(-2). Sound right?
looks good to me!
Prosthetic Head said:
looks good to me!
Looks good to me as well.
(BTW, that was perfect timing with our previous posts, Prosthetic Head!)
Thanks again!
  • · Replies 17 ·
