Calculating Total Power Emitted by a Black Body in a Spherical Chamber
The discussion focuses on calculating the total power emitted by a black body in a spherical chamber, specifically addressing the relationship between reflectance, emissivity, and emitted power. The formula used is P=σεAT^4, where the emissivity is determined to be 0.6 due to a reflectance of 0.4. The correct total power emitted by the chamber is σT^4 per unit area, as the reflected radiation from the body does not contribute to the power emitted from the body itself.
  • Understanding of black body radiation principles
  • Familiarity with the Stefan-Boltzmann law
  • Knowledge of emissivity and reflectance concepts
  • Basic grasp of thermal equilibrium in closed systems
  • Study the Stefan-Boltzmann law in detail
  • Learn about emissivity and its impact on thermal radiation
  • Explore the concept of thermal equilibrium in spherical geometries
  • Investigate the differences between radiating and emitting in thermal physics
Students in physics or engineering, particularly those studying thermodynamics, as well as professionals working with thermal systems and radiation analysis.
Krushnaraj Pandya
A spherical body is enclosed in a spherical chamber which acts like a perfectly black body. The reflectance of the body is 0.4 and transmittance is negligible, the temperature of the body and surrounding temperature is constant at T Kelvin. The total power that comes out of the body per unit area is?
P=σεAT^4
reflectance is 0.4 so emissivity is 0.6, power radiated by body per unit area is 0.6σT^4 but the correct answer is σT^4- where am I wrong? I think the reflected radiation shouldn't be counted as coming "out" from the body
If that's the case, from where did the spherical chamber get the radiation it's emitting?
I am confused between the terms "radiating" and "emitting". Are they considered the same?
Yes.
So this is what's going on- the chamber emits σT^4 (per unit area), the body emits 0.6 of it back and reflects 0.4 of it back, correct?
Yes.
haruspex said:
Yes.
Thank you very much :D
