Black Body Radiation: Facts & Overview
The discussion focuses on solving problems related to black body radiation using geometric series and reflectivity calculations. The user successfully derived the emerging power from surfaces by applying the formula R=1-ε and incorporating the Stefan-Boltzmann law, εσT4. Additionally, they explored summing two geometric series to compute power incident on surfaces, leading to a clearer understanding of the power absorbed by the second surface.
  • Understanding of black body radiation principles
  • Familiarity with the Stefan-Boltzmann law
  • Knowledge of geometric series and their summation
  • Basic concepts of reflectivity in thermal radiation
  • Study the derivation of the Stefan-Boltzmann law in detail
  • Learn about the applications of geometric series in physics problems
  • Explore the concept of reflectivity and emissivity in thermal systems
  • Investigate advanced topics in thermal radiation and cavity radiation
Students and professionals in physics, particularly those focusing on thermodynamics and thermal radiation, as well as educators looking for effective methods to teach black body radiation concepts.
LCSphysicist
I am really stuck at this question, i would appreciate any tips you have. I already try to goes with series but the calculation is getting harder and tiring, so probably this is not the right way.
Edit: I got a correct answer by assuming a left going and a right going power at each of the two surfaces. I then used the reflectivity as ## R=1-\epsilon ## and multiplied this by the incident power (per unit area), and added this term to ## \epsilon \sigma T^4 ## to get the emerging power from the surface. You do this for both surfaces. You then get expressions for left going and right going power inside the cavity.
additional note: I initially misread their nomenclature. They do have the correct answer.
Edit 2: I have now also worked it by summing two geometric series. That method is also fairly straightforward=if you show a little of your own attempt at this method, I can probably show you any steps that you might be missing.
Hint: Compute the power incident on the ## T_2 ## surface that originates from the first surface using a series. Next compute the power that is incident on the ## T_2 ## surface that originated from the same surface using a series. They are both geometric series, and are readily summed. Once you have that, what is the power absorbed by the second surface?
