Block bombarded by particles {colision}
  • Thread starter Thread starter LCSphysicist
    Block Particles
15 replies · 1K views
LCSphysicist
A trouble with quantity of motion, impulse and force.
All below
I thought i could apply a conservation of momentum in this case,
Apparently, this is not right, so i don't know what to do now.
I suggest you have a look at the formulas here https://en.wikipedia.org/wiki/Elastic_collision#One-dimensional_Newtonian and do the proper approximations for the case that ##m_2=\delta m<<m=m_1##.
According to one approximation I can see for this case (namely that ##m+\delta m\approx m## )we ll have $$v_{n+1}=(1-\frac{\delta m}{m})v_{n}+\frac{2\delta m}{m}v_0$$. What do you get for ##v_n## ( the velocity after the n-th collision) if you solve this recursive equation?
I use wolframalpha to solve this, because i am little tired now, but we have:
I think this is not the answer, because if n tends to infinity {just to verify and to comparison with the problem}, Vn will diverge and so will not tends to Vo
I see, maybe the approximations I have suggested are not so good. What do you get in wolfram alpha if you want to solve the recursive equation $$v_{n+1}=bv_{n}+av_0$$ for ##1>b>0## and ##1>a>0## cause I don't seem to get something valid there.
The exact recursive equation I get (without approximations) is
$$v_{n+1}=\frac{m-\delta m}{m+\delta m}v_n+\frac{2\delta m}{m+\delta m}v_0$$
LCSphysicist said:
Homework Statement:: A trouble with quantity of motion, impulse and force.
Relevant Equations:: All below
View attachment 264183View attachment 264182
How do you get the ##2V+v_0##? Does your equation make sense when ##V=v_0##?
You must need to use the elasticity somewhere.
You are doing to much on behalf of the OP. Please just provide hints and point out errors, at least to begin with.
Sometimes in physics a successful result involves the art of making successful approximations. I think this is the case here, it's all about making the proper approximations here stemming from the fact that ##\delta m<<m##.
I wonder i could change to the reference of the block, but this is leading me to some contradictions. I don't know why, see example:
A ball is going with 50m/s, and the block 30m/s.
Now the ball has 20m/s in block frame, and go back with -20m/s
But in the block frame, the ball has
+20 + 30 = +50
-20 + 30 = +10, what is wrong, because the ball need to back off.
Considering the mass of the block very large with respect to the ball.
Maybe i just can use this when the two blocks are approximating?
In this cases that have something a >> b, i always try to put b/a and so i cut this terms, because is nearly zero, but in this case seems that don't match, i will try by another approximations.
It's possible to solve this by rearranging it to $$(m + \delta m)v_{n+1} - (m - \delta m)v_n = 2v_0 \delta m$$and then solving the non-homogenous recurrence relation. To do this you postulate ##v_n = \lambda^n## for the homogenous part, and ##v_n = k## for the non-homogenous part. I won't show details since we can't give full solutions, however you end up with something like ##v_n = v_0(1-e^{-n\ln{(\frac{m+ \delta m}{m - \delta m})}})## which you can then get into the required form along with ##\ln(1+x) \approx x##.
There's likely a nicer way, but it gets the job done 😅.
Yes, now i got it. THanks all of you.
I am just stuck in this,
+20 + 30 = +50
There is any error in see by this way?
The problem just states that the particles bounce back in the negative x-direction, i am not sure if we can interpret this as that they bounce back with equal and opposite velocity (relative to the block). If we interpret it this way then because the collision is elastic and hence kinetic energy is conserved this would imply that the particle transfers zero kinetic energy to the block, so the velocity of the block would remain constant.
Then either momentum is not conserved or the block has turned into a brick wall.
Elastic collison so ##\Delta P = 2\mu\Delta v## where ##\mu = \frac{m\times M}{m+M}\approx m## if m<<M and ##\Delta v=v_0-v_n##. Then ##P_{n+1}=P_n+\Delta P##.
