Block on plate with time-dependent applied force
45 replies · 10K views · last reply
jisbon
Block of mass m = 0.5kg sits on top of large plate with mass M = 1.5kg. Contact surface of plate and ground is friction less and coefficient of static and kinetic friction is 0.9 and 0.5 respectively. System is originally at rest and external force F(t) = 2t N (where t is time in seconds) is used to pull the block. Until block starts to slide, after which F is maintained at value in part (a). Assume plate is long enough such block doesn't fall off plate.
(a) Calculate external force F at moment before block starts to slide on the plate.
(b) Calculate how far plate will travel relative to ground 1s after block slips.
(c) Calculate how far block travel relative to the ground 1s after it slips.
s=ut+0.5at^2
F=ma
Question as follows:
My answer/explanation:
Force needed to make block slide = static friction between block and plate.
So friction = normal of block * static friction = (0.5∗9.8)∗0.9=4.41N(0.5∗9.8)∗0.9=4.41N
My thoughts/wrong answer probably?: after block slips, plate experience
kinetic friction = (1.5∗9.8)∗0.5=7.35N(1.5∗9.8)∗0.5=7.35N
To find distance , use
s=ut+0.5at2 where u=0, so s=0.2at2s=0.2at2
To find a, F=ma
Since plate only experience kinetic friction(?),
a=7.35/2a=7.35/2 (including block on plate) = 3.6753.675
s=0.5(3.675)=1.8375s=0.5(3.675)=1.8375m to the left?
Do help explain if it's wrong. Thanks
Using similar concepts as above, After 1s,
F= 2t N= 2(1)(4.41)=8.822(1)(4.41)=8.82
Friction = 0.5∗0.5∗9.8=2.450.5∗0.5∗9.8=2.45
a=8.82−2.45/0.5=12.74a=8.82−2.45/0.5=12.74
s=0.5(12.74)(1)2=6.37ms=0.5(12.74)(1)2=6.37m to the right?
Help will really be appreciated. Thanks
That would be true if the plate were held fixed. But plate and block can accelerate.
Consider the net horizontal force on the block. What equation can you write?
Net force on block = external force - static friction between block and plate ?
I can't seem to figure out how if plate moves in the opposite direction, it will affect the force on the block :(
Free-body diagram of a block resting on a plate, with a rightward applied force F on the block and a leftward static friction arrow acting on the block at the contact surface.
Right. Now consider acceleration (a) of the block and (b) of the plate.
Acceleration of block = (F-static friction)/mass of block
Acceleration of plate= static friction/mass of plate?
Free-body diagram of a block on a plate: arrows mark normal force up, mg down, external force to the right on the block, and friction on the block to the left, with a friction arrow on the plate to the right.
Right. And as long as the block is not sliding on the plate, how can you connect those equations?
If block is not sliding, does that mean both block and plate has the same acceleration?
Yes.
haruspex said:
Yes.
Okay, so going back to the question:
So I assume to slide, Acc of block must be more than acc of plate.
So in this case,
[tex]\frac {F-friction} {mass of block} = \frac {friction} {mass of plate+block?}[/tex]
And solve for F?
I have also been thinking about part b: (b) Calculate how far plate will travel relative to ground 1s after block slips.
So after it slips, the question states that F is maintained at value in part (a), yet there is formula given [tex]F=2t N[/tex] In this case, which should I actually follow?
Thank you
Where did the +block come from?
That was not in your post #5.
Oh because I figured to make the mass includes the block since the plate is technically carrying the block, or is it not?
In post #5 you wrote, correctly
That comes from consideration of the forces on the plate.
If you want to treat the plate and block as an item the frictional force between them becomes an internal force and will not appear in the ΣF=ma equation.
oh yep that actually makes sense now. i got part a to be 4.41N. Now regarding part b:
So after it slips, the question states that F is maintained at value in part (a), yet there is formula given [tex]F=2tNF=2tN[/tex]
No, that's what you had originally. You should be getting a different answer using your equations in post #5.
The formula ceases to apply once the block starts to slip.
I'm not sure what part b is asking. Does it want the whole distance traveled by the plate, from rest, at a point in time 1 second after slipping starts, or does it want the distance traveled during the 1 second after slipping starts? It sounds like the latter.
Either way, you will need to find the velocity when slipping starts.
Hm that's weird let me see again:
So part (a) is:
[tex]\frac {F-friction} {mass of block} = \frac {friction} {mass of plate}[/tex]
Friction = [tex](0.5*9.8)*0.9 = 4.41N[/tex]
So[tex]F = (\frac {friction} {mass of plate} * mass of block) + friction[/tex]
= [tex](\frac {4.41} {1.5} * 0.5) + 4.41[/tex]
= 5.88N
Will this be the final answer?
Regarding part b, I think the questions wants the distance traveled during the 1 second after slipping starts. So how should I start? By finding the initial velocity when it starts to slip? Or..? Thanks!
jisbon said:
= 5.88N
Yes.
Yes, you will need to do that, and find the subsequent acceleration.
haruspex said:
Yes.
Thanks for part a.
Regarding b, I can;t figure out how plate has a initial velocity, because what I thought is it initially at rest and only starts accelerating due to the kinetic friction, hence my workings as follows:
Kinetic friction =[tex](1.5∗9.8)∗0.5=7.35N[/tex]
[tex]s=ut+0.5at^2[/tex] where u=0, so [tex]s=0.5at^2[/tex]
To find a, [tex]F=ma[/tex]
[tex]a=7.35/2a=7.35/2[/tex] (including block on plate) = 3.6753.675
[tex]s=0.5(3.675)=1.8375m[/tex]
Could I have a hint or sort on where do I get my initial velocity? Thank you
There is no friction between plate and ground, but as soon as F > 0 there is friction between plate and block, so the plate accelerates.
So with that I gathered, I supposed the plate is already moving even when block did not start to slide on plate, but how am I suppose to find the initial velocity of the plate? I'm kind of stuck right here :(
At what time does the block start to slide?
Up until that point, they move together under the force F. What is the acceleration as a function of time, and how does that turn into speed as a function of time?
Block only starts to slide at t seconds (Using the formula ##F(t) = 2t N##, so only starts to slide at ##t= \frac {F}{2N} = \frac {5.88N}{2*9.8*0.5} = 0.6 seconds##
Acceleration as a function of time (not sure what you meant by this but do you mean): ## a= \frac {dv}{dt}##?
I still can't figure out how finding the time taken for block to slide will give the inital velocity tho :(
Yes, but you know force as a function of time and you know the mass, so...
Won't the inital velocity = when t = 0, which means that## F(t) = 2t N = 0##? If F=0, won't there be any acceleration?
When t=0 there is no acceleration, but a fraction of a second later there will be.
Please try to write the equation connecting the given force function with the equation I quoted in post #22.
##F(t) = 2t N## and
##a = \frac {dv}{dt}##
Is it correct to state that ## \frac {2tN}{mass of plate} = acceleration##?
jisbon said:
##F(t) = 2t N## and
Yes.
No. Use your post #5 equations again, this time eliminating frictional force.
haruspex said:
Yes.
If I eliminate friction from:
##Acceleration of plate= static friction/mass of plate##
Won't there be any acceleration?
I said to use the two equations in a way that eliminates the static friction force. You should be left with an equation relating F, acceleration and mass.
jisbon said:
##F(t)=2tN## and
##a= \frac {dv}{dt}##
Since static friction = static friction coefficient* N,
N = \frac {F}{2t}
##static friction = \frac {F}{2t} * static friction coefficient## =
##Acceleration of plate= \frac{\frac {F}{2t} * static friction coefficient}{mass of plate}##
Do you mean this by any chance? Thanks
N = \frac {F}{2t}
No.
In post #5 you had two equations which I will abbreviate as ##a=\frac{F-f_s}{m_b}## and ##a=\frac{f_s}{m_p}##.
Previously, you combined them so as to eliminate a and found the relationship between F and fs. Now I am asking you to combine them so as to eliminate fs instead, and hence find the relationship between F and a.
