Understanding the Relationship Between Baryonic and Dark Matter in the Universe
  • Thread starter Thread starter RyanH42
RyanH42
We know that ΩDM=0.26
and ΩBM=0.46 which this leads us this result ΩDM=5ΩBM
So In universe If there's m baryonic matter there will be 5 times more dark matter (5m).This is true in larger universe distances
Milky way galaxy mass is 9x1010 solar masses but dark matter value is nearly 20 times bigger then that (average of 6x1011 and 3x1012) so here ΩDM≅20ΩBM
So universe contains 5ΩBM
and our galaxy contains ≅20ΩBM.
Is that mean some places there's no DM nearby the galaxy or not nearby galaxy places ?
Space news on Phys.org
Our galaxy is actually a fairly small scale when you're talking about total densities of the observable universe. The matter distribution of the universe doesn't become homogenous until MUCH larger scales. Galaxy clusters are more representative structures for the rest of the universe, as over 90% of the baryonic matter is gas within the IGM. At the galactic scale most of the baryonic matter is from stars
I believe the answer you're looking for is that yes, outside of galaxies the ratio of DM/BM is slightly lower than average. It makes sense if you consider how lambda CDM predicts that DM is key to the formation of galaxies
Likes RyanH42
To be nit picky, only because the number is so critical to your analysis, you mean to say that ΩBM=0.046.
More generally, there are well established phenomenological relationships between the BM in a galaxy or galactic cluster defining total mass as a function of a single BM variable (with a kinked curve that breaks with different galaxy types) in any given system for the entire universe, subject to only modest random scatter. Matter, BM and DM alike, is overwhelmingly clumped in galaxies and galactic clusters which are strongly clumped in huge filaments of matter between large voids which very low densities of matter by comparison.
Thus, the BM/DM ratio is largely a function of the distribution of galaxies and galactic clusters by size in the universe. As very crude a rule of thumb, smaller galaxies tend to have higher DM/BM ratios than larger galaxies (at least within a given type of galaxy and comparing the mean for different types of galaxies), but clusters have quite high DM/BM ratios. The universe's DM/BM ratio of 5 corresponds to a weighted mean galaxy size in the universe corresponding to the mass that has a DM/BM ratio that is typically about 5. A typical elliptical has about a 2-1 ratio of DM-BM, while a typical spiral galaxy like the Milky Way is closer to 20-1 or 12-1. A 5-1 ratio seen in the universe as a whole is at the low end for spiral galaxies (and thus associated with larger spirals with bulges) and at the high end for elliptical galaxies (and associated with smaller elliptical galaxies that aren't perfectly spherical).
Likes RyanH42
As I understand it, it's probably mostly a feature of galaxy formation. When the stars first turn on in smaller galaxies, a lot of the normal matter gets expelled from the galaxy. Larger galaxies have stronger gravity, which prevents most of the normal matter from escaping, but some still does.
I always thought it was odd that we know dark energy expands our universe, and that we know it has been increasing over time, yet no one ever expressed a "true" size of the universe (not "observable" universe, the ENTIRE universe) by just reversing the process of expansion based on our understanding of its rate through history, to the point where everything would've been in an extremely small region. The more I've looked into it recently, I've come to find that it is due to that "inflation"...
  • Featured
  • · Replies 37 ·
  • · Replies 18 ·
