Solving the Schrodinger Eqn for 1-D Atom
  • Thread starter Thread starter glebovg
    Atom Schrödinger
The discussion focuses on solving the Schrödinger equation for a one-dimensional atom using the wave function \(\psi(x) = Ax e^{-bx}\). It establishes that a solution can be derived for \(b = \frac{1}{a_0}\), where \(a_0\) is the Bohr radius. Key conditions for the wave function include \(\psi(x) \to 0\) as \(x \to \infty\) and \(\psi(0) = 0\), ensuring normalizability and reflecting the physical constraints of atomic structure. The ground state energy expression is derived as \(E = -\frac{b^2 \hbar^2}{2m}\), leading to the calculation of the Bohr radius by substituting known constants.
  • Understanding of the Schrödinger equation in quantum mechanics
  • Familiarity with wave functions and their properties
  • Knowledge of the Bohr model of the atom and the concept of the Bohr radius
  • Basic calculus for solving differential equations
  • Study the derivation of the Schrödinger equation for various potential energy functions
  • Learn about wave function normalization and its implications in quantum mechanics
  • Explore the calculation of ground state energies in quantum systems
  • Investigate the physical significance of the Bohr radius in atomic physics
Students and professionals in quantum mechanics, physicists working on atomic models, and anyone interested in the mathematical foundations of wave functions and their applications in atomic theory.
glebovg
By substituting the wave function \psi (x) = Ax{e^{ - bx}} into the Schoedinger equation for a 1-D atom, show that a solution can be obtained for b = 1/{a_0}, where {a_0} is the Bohr radius.
- \frac{{{\hbar ^2}}}{{2m}}\frac{{{d^2}\psi (x)}}{{d{x^2}}} - \frac{{{e^2}}}{{4\pi {\varepsilon _0}x}}\psi (x) = E\psi (x).
{a_0} = \frac{{4\pi {\varepsilon _0}{\hbar ^2}}}{{m{e^2}}}
I get to the point where 2b - x{b^2} = \frac{{2m}}{{{\hbar ^2}}}Ex + \frac{m}{{{\hbar ^2}}}\frac{{{e^2}}}{{2\pi {\varepsilon _0}}}. If I let x = 0 I get the desired result. Can I do that?
Apparently the wave function solving the equation must satisfy two conditions:
\psi (x) \to 0 as x \to \infty
\psi (0) = 0
But why is that? Can anyone explain?
\psi (0) = 0
The first condition is necessary because the wavefunction must be normalisable. Meaning it must have a finite integral over all space. If it tended to anything other than 0, then this would not be the case.
The second condition is necessary because you are talking about an atom. Atoms have a positive nucleus. There is no probability of finding an electron at exactly the centre of the nucleus.
Can you help? How do I show that b = 1/{a_0}?
What should E be?
Also, how to derive the expression for the ground state energy?
You need to recognise that in the ground state x = a_0 = 1/b and therefore E = -\frac{b^2 \hbar^2}{2m}. Thus you can cancel the terms for x from the equation and calculate the bohr radius by plugging in known values of the constants. This also leaves you with an equation for calculating the ground state energy.
So you just equate the coefficients and then solve for both b and E, right?
Yeah.
Thanks.
