Does Moving a Wire Increase its Magnetic Field?
The discussion centers on the effects of moving a wire carrying current on its associated magnetic field. When a wire is moved upward at a constant speed, the magnetic field does not increase at a fixed point; instead, the Lorentz factor indicates that the magnetic field's characteristics change due to relativistic effects. The wire, when analyzed in its rest frame, reveals a transverse electric field and is not uncharged, contradicting many textbook assumptions. This phenomenon is explained through the relativistic treatment of Ohm's Law and the self-induced Hall effect.
  • Understanding of classical electromagnetism
  • Familiarity with special relativity concepts
  • Knowledge of Lorentz transformations
  • Basic principles of electric and magnetic fields
  • Study the Lorentz boost in electromagnetism
  • Explore the self-induced Hall effect in current-carrying wires
  • Review the relativistic treatment of Ohm's Law
  • Investigate the implications of moving charges on electric and magnetic fields
Physicists, electrical engineers, and students studying electromagnetism and special relativity who seek to deepen their understanding of the interaction between moving currents and magnetic fields.
jamesconnolly81
Folks,
I'm not sure if this is the correct forum topic for my question, but it seems to be close or related.
Question: If you have a wire carrying current then it creates a magnetic field as in the diagram in the link below.
https://nationalmaglab.org/educatio...ay/interactive/magnetic-field-around-a-wire-i
The electrons are moving upwards. What happens if you then move the wire itself upward at a constant speed ?
Does that in any way add to or help the current in any way ? In other words does the magnetic field increase when measured at a fixed point ?
Thanks James
@vanhees71 gave the mathematical answer, so I will add a qualitative answer. Around an uncharged current-carrying wire we have no E field and the B field is in the plane perpendicular to the wire.
You can use the equations in this link to determine the fields in a frame where the wire is moving: https://en.m.wikipedia.org/wiki/Classical_electromagnetism_and_special_relativity
Briefly, you get an E-field pointing radially outward from the wire and the B field increases by the usual Lorentz factor.
But in the rest frame of the wire you have a transverse E-field (in addition to the E-field along the wire keeping the current flowing), and the wire is not uncharged! That's the important point of the above quoted Insights article. Amazingly the relativistic treatment of the current-conducting wire is wrong in many textbook by just assuming that the wire is uncharged in the wire restframe, which however is wrong due to the correct relativistic version of Ohm's Law. As shown in the Insights article (and the nice paper quoted in there), the wire is uncharged in the rest frame of the conduction electrons. All this is easily understood as a consequence of the "self-induced Hall effect" on the current.
  • · Replies 20 ·
  • · Replies 28 ·
  • · Replies 22 ·
