Boric acid + Isopropyl alcohol = ?
  • Thread starter Thread starter jorjor
    Acid Alcohol
The discussion centers on the combination of boric acid and isopropyl alcohol in an ant killer solution. The user successfully created a mixture using 4.9 grams of boric acid, 39.4 grams of table sugar, and 250ml of water. Upon adding 2 tablespoons of 91% isopropyl alcohol to the solution, a cloud of small bubbles formed, prompting questions about potential chemical reactions or gas release. The user notes the importance of handling boric acid safely due to its toxicity.
  • Understanding of boric acid properties and applications
  • Knowledge of isopropyl alcohol and its uses in sterilization
  • Basic chemistry concepts related to solubility and gas release
  • Familiarity with ant control methods and formulations
  • Research the chemical interactions between boric acid and glucose
  • Learn about the properties and uses of isopropyl alcohol in pest control
  • Investigate the effects of adding alcohol to aqueous solutions
  • Explore safe handling practices for boric acid in household applications
This discussion is beneficial for DIY pest control enthusiasts, chemists, and anyone interested in safe and effective ant management solutions.
jorjor
Hi...I've made some ant killer solution:
39.4 grams of table sugar (sucrose?),
in 250ml water
Works fine. Take 1/4 of a paper towel, fold into a small rectangle, place on inverted saucer,
and saturate with ~1 tsp of Ant-B-Gone. When the paper pad is dry, dispose, rinse saucer,
and replace with new pad+solution. Wash hands, because boric acid is toxic, but not so much
that you can't use it in the kitchen, for example.
(Included this level of detail for completeness and because it might be of general use.)
OK. This evening I went to the jar of Ant-B-Gone to renew a pad, and saw floating toward the
bottom a ~2cm sphere of very fine fibers radiating from a denser center. Not a crystal, but
probably a fungal growth of some sort. I fished it out with a spoon and added 2 tablespoons
of 91% isopropyl alcohol to sterilize the solution, thinking that on application the alcohol would
evaporate.
Funny thing is, though, when I swirled the solution to mix it, a cloud of very small bubbles
appeared.
Question: did a reaction occur, resulting in something that isn't boric acid any more, or (perhaps)
did the addition of the alcohol bring dissolved gases out of solution?
Chemistry news on Phys.org
Boric Acid and Glucose reacts to form a complex. Maybe that has something to do with this.
16K
