Designing a Bouncing Egg-Drop Container with Springs
  • Thread starter Thread starter hushnow
    Container
The discussion revolves around designing a bouncing "egg-drop" container that incorporates springs, with the goal of protecting a raw egg during a drop from a height of 1.0m while maximizing the number of bounces. Participants explore material options and design strategies to achieve effective cushioning and directional bouncing.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants discuss various materials for cushioning, such as bubble wrap and sponges, and question the necessity of using springs exclusively. Ideas include surrounding the container with springs to enhance bouncing efficiency and suggestions for coiled spring designs that could dissipate energy effectively.
The conversation is ongoing, with participants sharing ideas and clarifying constraints regarding the use of springs. Some suggestions have been made regarding design and material combinations, but no consensus has been reached on a definitive approach.
Participants are constrained by the requirement to use springs as part of the design, and there is a specific focus on achieving controlled bouncing in a designated area upon impact.
hushnow
Hello! :smile:
Could you please help me with materials and design ideas for a bouncing "egg-drop" container?
I have to make a bouncing "egg-drop" container that must be made with springs.
Any materials (except liquid) may be used.
The container will be dropped from 1.0m to the floor and it must protect a raw egg while achieving the largest number of clear bounces.
I think that protecting the egg part is fairly easy. What I need would be good cushioning and shock absorbing materials such as bubble wrap, sponges, etc. The springs (which I must use as one of the materials for the container) would also help reduce the impact. However, I don't know what kind of design would make the container to bounce most effectively. :confused:
The really difficult part is making it bounce in a same direction on a specific, small area of surface (where it is dropped on at first, not boucing off to other random areas)... :rolleyes:
Please help! I would great appreciate any advice or ideas. :wink:
does it absolutely have to be a "spring" or can you use some other material that makes the container bounce? i could think of ways to get it to bounce much more efficiently if you can use other materials
as far as helping with the directional problem, surround your container with springs so that it will bounce no matter which way it lands
How about a simple coiled spring, like a spring powered device winding, that surrounds a central egg container.
It should dissipate energy from any direction along the plane provided its dropped perpendicular to the coil axis.
Yes. Unfortunately, springs must be used as one of the materials for the container. :(
So, I would just need to attatch many springs around the container...
Thank you for your nice idea! :)
I really like your idea, but it is difficult for me to find a spring that big... :blushing: Thanks a lot, anyway! :)
  • · Replies 25 ·
