What is the height of the ice above water level in each glass?
The discussion focuses on determining the height of ice above water level in two identical glasses, one filled with fresh water (density 1 gm/cm3) and the other with salt water (density 1.025 gm/cm3). The ice cube, with a density of 0.92 gm/cm3, displaces water according to Archimedes' principle. The calculations reveal that the height of the ice above water in fresh water is 0.08 cm, while in salt water it is 0.105 cm. The key takeaway is that the height of the ice above water level is determined by the difference in densities between the ice and the liquid.
  • Understanding of Archimedes' principle
  • Knowledge of density and buoyancy concepts
  • Basic algebra for calculating displacement
  • Familiarity with the properties of fresh and salt water
  • Study Archimedes' principle in detail
  • Learn about buoyancy and its applications in fluid mechanics
  • Explore density calculations for various liquids
  • Investigate the effects of salinity on buoyancy in marine environments
This discussion is beneficial for students studying physics, particularly those focusing on fluid mechanics, buoyancy, and density calculations. It is also useful for educators looking for practical examples to illustrate these concepts.
gc33550
Two Identical glasses are filled to the same level. One is filled with fresh water (density=1 gm/cm^3) and the other with salt water (density=1.025g/cm^3) Into each glass a cube of ice (density= 0.92 gm/cm^3) one cm on each side is placed. What is the height of the ice above water level in each glass?
Maybe Archimedes' principal? We never really went over this in class
I honestly have no idea... Do we subtract the densities to get the cm of displacement? Like the ice in freshwater is .08 becase 1-.92=.08? I am truly lost.
Welcome to PF.
That's pretty much it ... for plain water.
Now what about the salt water?
Well if that were the case for the freshwater I would assume it to be the same for the salt water. so 1.025-.92=.105? It just seems to simple for the final exam I suppose. But if this is correct can you offer any explanation why we simply subtract the densities?
Salt water is a little different. Your first result was a consequence of the fact that fresh water was given as a density of unity.
Buoyancy is the amount of weight displaced isn't it? (I'm letting gravity cancel out here.) So all the cube needs to displace is .92g . The mass that the cube could displace and be even would be 1.025 g. So the percentage of the cube that will be poking out will be .92/1.025 subtracted from 1 won't it?
Well that does give me an answer on the exam but I don't have an answer key and I don't really understand why I suppose... Maybe I just don't really understand bouyancy
Here is a lecture that covers it in a little more detail:
https://www.youtube.com/watch?v=ngABxM7jl0Q
Ok so that makes a bit more sense. But it is the Mass of the object-the apparent mass of the object submerged=the density of water*volume of the object... So how does this relate to my problem? are we solving for the mass of the object submerged? giving us mass (which in this case would be .92) divided by the density of the saltwater*volume of the object (which is one)?
You are solving for the displacement of the water necessary to hold up the object. The cube weighs .92 grams as ice. How much liquid water does it need to displace in order to provide .92 grams of buoyant force? Once that amount of water is displaced, then it is in equilibrium and it is floating.
  • · Replies 21 ·
  • · Replies 16 ·
21K
