Boxes, cables, and girders (torque and equilibirum problem)
  • Thread starter Thread starter SageOwl
    Cables
SageOwl
Usually I'm pretty good with torque and such but this one had me.
A box of mass 75 kg is put on a 10-m long steel beam of mass 150 kg and is connected to the wall and supported by a steel cable. The box is located 2.5 m from the wall and the cable makes 60o angle with the beam. What are the magnitude and the direction of the force exerted by the wall on the beam?
Torque=Radius x Force, upwards/clockwise torque=downwards/counterclockwise torque, weight=mass x gravity
I was able to find the tension in the cable, if that helps (14321.475N), but otherwise I'm clueless.
Kind of odd using a 10 m long beam to support a box only 2.5 m away from the wall. Or have I misunderstood?
The usual approach is to write that the sum of the moments about a point (in this case the point where the beam attaches to the wall) is zero. I can't go much further until you give it a try and show your work here.
