Brake Power, Engine Speed and bmep Relationship
2 replies · 9K views · last reply
smr101
I'm currently doing a report on Petrol Engines and I'm having a problem with my results not making sense.
Am I correct in saying Break mean effective pressure (bmep) should increase as Engine Speed (rev/min) increases? My results do not reflect this and I don't understand why.
I have attached my results table below, I calculated brake power and bmep myself using these equations:
Formula for brake power written as Brake Power = 2πT × N / 60, with 2πT × N in the numerator and 60 in the denominator.
Equation for brake mean effective pressure: pb = brakepower × K × 60 divided by A L N n, with brakepower × K × 60 as the numerator and A L N n as the denominator.
I believe the problem is in the Brake Power & bmep results, help is much appreciated.
Results table of 11 test runs listing brake drive, engine speed in rev/min, torque in Nm, brake power in kW, bmep in kN/m², volumetric efficiency in % and air volume flow rate in m³/s.
I think the following quote from the above reference site addresses your concern:
The definition of BMEP is: the average (mean) pressure which, if imposed on the pistons uniformly from the top to the bottom of each power stroke, would produce the measured (brake) power output.
While the equations shown are based upon torque, in fact BMEP is really a measure primary of the filling efficiency of a cylinder during the intake stroke combined with fuel combustion energy; and, neither of these factors are related to engine speed. In reality, there is a potential for a reduction in BMEP at increased engine speeds due to a flowing pressure drop in the engines inlet system as the engine demands higher and higher air cfm flow rates. Increasing BMEP by raising the cylinder(s) air charge pressure is the primary reason for and function of superchargers and turbochargers. i.e. higher cylinder charging pressure = higher compression pressures and more air to be expanded during the combustion power cycle.
Added note: BMEP can also be potentially reduced at increased engine speeds due to the fact that the piston's downward travel rate is increased during the power stroke which in turn increases the cylinder volume increase rate relative to the cylinder's reduced combustion pressure rise burn time; this is where ignition timing and variable valve timing functions can come into play to offset this effect.
