Brillouin Zone Size: Debate Settled
The area of any 2D Brillouin zone is defined as (2π)^2/V, where V is the area of the unit cell in real space. For a square lattice with lattice constant 'a', the area is (2π/a)^2. This relationship holds true for all lattice types, including square, oblique square, and hexagonal, although the specific area calculations may vary based on the lattice geometry. The correct understanding of lattice spacing in reciprocal space is crucial for accurately determining the area of the Fermi circle and other related properties.
  • Understanding of Brillouin zones in solid state physics
  • Familiarity with reciprocal lattice vectors
  • Knowledge of unit cell geometry in 2D lattices
  • Basic principles of solid state physics and crystallography
  • Study the derivation of Brillouin zone areas for different lattice types
  • Learn about the calculation of primitive vectors in reciprocal lattices
  • Explore the relationship between real-space and reciprocal-space cell volumes
  • Investigate the implications of lattice spacing on electronic properties in solid state physics
Students and researchers in solid state physics, particularly those preparing for exams or working on crystallography and electronic properties of materials.
RadonX
Hi guys,
Me and a few of my coursemates are revising for a solid state exam but have hit a problem.
Is the area of every 2D brillouin zone (independent of lattice type) (2Pi/a)^2?
For a square lattice in 2D real space with lattice constant, a, the reciprocal lattice vectors can easily be found (with magnitudes of 2Pi/a, right?) and so the brillouin zone in reciprocal space has a area of (2Pi/a)^2.
Half of us are under the impression that this area is true of ALL brillouin zones of varying lattice type (square, oblique square, hexagonal etc), the other half are of the thought that you define the lattice spacing as 'a' and therefore the brillouin zone sizes vary.
Particularly, for a hexagonal lattice this would render an area of 2/sqrt(3)*(2Pi/a)^2.
Obviously the lattice spacing in reciprocal space is important for answering questions on the area of the fermi circle etc.
Hope someone can help us! This is causing a lot of debate!
Thanks,
Will
The area of any Brillouin zone is (2Pi)^d/V where d is the dimensionality, and V is the "volume" of the real-space crystal. In 2D, V is the area of the unit cell, a*a fora square lattice, a*b for a rectangular lattice, and something else for other shapes of cells.
You remember how to calculate the primitive vectors of the reciprocal lattice, right? They satisfy
\vec{a}_i \cdot \vec{b}_j = 2\pi \delta_{i,j}.
For three dimensions, you can calculate the volume of the unit cell by (\vec{a}_1 \times \vec{a}_2) \cdot \vec{a}_3. Do the same for the reciprocal cell and with the relationship above you can prove that the product of the volumes of the real-space cell and the reciprocal cell is (2pi)^3. Carry out the same procedure for 2D and you should be able to prove to your friends the correct relationship.
Daveyrocket!
Thank you very much! That's a great help.
Just checking through our stuff to see if we get your (2pi)^3 result when multiplying the reciprocal cell by the real space cell.
We get (2Pi)^2 in our case which makes sense for a 2d lattice area we think?
Yes that is correct.
  • · Replies 18 ·
9K
10K
9K
10K
