Browder Proposition 8.14: Why does r(tv)/t approach zero as t→0?
  • Topic:
  • Thread starter Thread starter Math Amateur
    Maxima
2 replies · 2K views
Math Amateur
MHB
I am reading Andrew Browder's book: "Mathematical Analysis: An Introduction" ... ...
I am currently reading Chapter 8: Differentiable Maps and am specifically focused on Section 8.2 Differentials ... ...
I need yet further help in fully understanding the proof of Proposition 8.14 ...
Proposition 8.14 reads as follows:
In the above proof by Browder, we read the following:" ... ... For any $$v \in \mathbb{R}^n$$, and $$t \gt 0$$ sufficiently small, we find (taking $$h = tv$$ above) that $$L(tv) + r(tv) \leq 0$$, or $$Lv \leq r(tv)/t$$, so letting $$t \to 0$$ we have $$Lv \leq 0$$. ... ... Now ... the above quote implies that
$$\lim_{ t \to 0 } \frac{ r(tv) }{ t } = 0$$ ... ... But why exactly (formally and rigorously) is this the case ... ... ?I note that we have that $$\lim_{ h \to 0 } \frac{ r(h) }{ |h| } = \lim_{ t \to 0 } \frac{ r(tv) }{ tv } = 0$$... but this is (apparently anyway) not exactly the same thing ... we need to be able to demonstrate rigorously that$$\lim_{ h \to 0 } \frac{ r(h) }{ |h| } = \lim_{ t \to 0 } \frac{ r(tv) }{ t } = 0$$ ... ... ... but how do we proceed to do this ...?Hope someone can help ... ...
Peter
==============================================================================EDIT:
Just noticed that in the above quote, Browder argues that $$L(tv) + r(tv) \leq 0$$ implies that $$Lv \leq r(tv)/t$$ ... ... ... BUT ... i suspect he should have written $$L(tv) + r(tv) \leq 0$$ implies that $$Lv \leq - r(tv)/t$$ ... ..... however ... in either case ... when we let $$t \to 0$$ we get the same result ... namely $$Lv \leq 0 $$... ==============================================================================
This is another case where you have to distinguish between fixed and variable vectors. Here, $v$ is fixed, but $tv$ varies, and goes to $0$ as $t\to0$. So $$\lim_{t\to0}\frac{r(tv)}{t|v|} = 0$$, and then you can multiply by the fixed nonzero scalar $|v|$ to get $$\lim_{t\to0}\frac{r(tv)}{t} = 0$$.
Absolutely correct! Browder has omitted a minus sign. But his conclusion is correct.
Opalg said:
This is another case where you have to distinguish between fixed and variable vectors. Here, $v$ is fixed, but $tv$ varies, and goes to $0$ as $t\to0$. So $$\lim_{t\to0}\frac{r(tv)}{t|v|} = 0$$, and then you can multiply by the fixed nonzero scalar $|v|$ to get $$\lim_{t\to0}\frac{r(tv)}{t} = 0$$.Absolutely correct! Browder has omitted a minus sign. But his conclusion is correct.
HI Opalg ...
Your post was most helpful to me ...
Peter
