Bullet hitting stationary Target.
  • Thread starter Thread starter Adarshaero
    Bullet
8 replies · 3K views
Adarshaero
A bullet of 0.005 kg traveling at 20m/s penetrates deeply into a fixed target and is brought to rest in 0.01 sec. The distace through which it penetrates is:
I used,
acceleration= V/t
= 20/.01
a = 2000 m/sec sq
Distace covered = Ut+0.5 at^2
= 20*0.01+0.5*2000*(o.o1)^2
S= 30cm.
Is it correct or any other solution is possible..?
The initial speed and the acceleration have opposite directions.
@willem2:
How is tat? can you please elaborate.
Does the bullet slow down or speed up as it moves through the block? So is acceleration positive or negative?
Acceleration reduces as the bullet enters the target.
so acceleration is negative...
The velocity reduces as it passes through the target. So yes, acceleration is negative (in the direction opposite to the velocity).
I understand ur point. So is the approach right? And how about answer?
The approach is fine. How about the answer? Have you calculated one with the new knowledge about the acceleration direction?
