Buoyancy - block of concrete is being raised from a lake
The discussion focuses on calculating the fraction of the weight of a 50kg block of concrete required to lift it while submerged in water, utilizing Archimedes' principle. Participants clarify the need to differentiate between the forces acting on the block in air and water, emphasizing the importance of using correct density values for concrete and water. The final expression for the ratio of forces is derived as (ρ_concrete - ρ_water) / ρ_concrete, leading to a numerical result of approximately 0.583, indicating that 58.3% of the block's weight in air is needed to lift it while submerged.
  • Understanding of Archimedes' principle
  • Knowledge of buoyancy and density calculations
  • Familiarity with Newton's laws of motion
  • Ability to manipulate algebraic expressions and ratios
  • Study buoyancy calculations in different fluid mediums
  • Learn about the implications of density in fluid mechanics
  • Explore applications of Archimedes' principle in engineering
  • Practice solving problems involving forces in equilibrium
Students of physics, engineering professionals, and anyone interested in fluid mechanics and buoyancy calculations.
KiNGGeexD
Buoyancy -- block of concrete is being raised from a lake
Question;
A 50kg block of concrete is being raised from a lake. What fraction of its weight in air is required to lift it while submerged?
My attempt,
I'm pretty sure this question pertains to Archimedes principle
I calculated the weight of the block (force due to gravity) and noted that the buoyancy force is equal to the weight of fluid displaced
Buoyancy = ρgV = ρgAy
And this is where it hit the buffers I'm not so sure how to proceed?
I think that it would be something like, calculate the buoyancy force and the force which would be needed to lift the block (in air) and then subtract the two as the buoyancy force would aid the elevation and then take some kind of ratio of that mass required and the given mass?Any help would be great I think I have given enough information:)
Thanks for any help in advanced:)
Regards
Buoyancy = ρgV = ρgAy is fine. Stick to V, because a "block" doesn't necessarily mean a rectangular block.
Something similar can be written down for the mass in terms of V and for the weight in air (check if you can ignore the buoyancy in air).
Since they want a fraction as a numerical answer, you will need the values of ##\rho## for concrete, water (and perhaps also for air).
Oh, and "submerged" can be taken to mean "fully submerged" I suppose.
Ok I will give it a go:)
Thanks a bunch I really appreciate it
So when I write mass in terms of ρV my volume is constant so I can cancel it and then go from there?
Do I start with the initial conditionmg = ρgV where density is that of concrete? Just so I know I'm on the correct path?
This is not initial condition. It is true all the time for the given block.
But it is one of the equations you need, yes.
So I would I then add the force applied to lifting the block
OK. What will be this force when the block is in air?
What will it be when it is submerged?
mg would be still acting downwards and force of pulling would be
F= ma?
When submerged the buoyancy aids the pulling force, and the only force acting down would be mg? Disregarding viscous forces and drag?
F= ma?
What is "a" here?
In Newton's law, F must be the net force. The sum of all the forces acting on the body.
Here you can assume uniform lifting, with no acceleration.
Ahh ok that helps a lot! I usually don't assume such things unless the problem states it explicitly, I'm the typical student who finds it hard to think on their own:(
So I am omitting acceleration as it is zero in this case?
ρVg = m(0)+ ρgV
Where the first rho is concrete density and the second is water?
What is m(0)?
That's what i don't get if the acceleration is zero the
F= ma would be zero?
Yes, the net force will be zero. This means that the forces acting on the body are balanced.
For the case in air, you have two forces: the weight of the block and the force pulling up.
You said that the weight is ρgV. What is the force pulling up, taking into account that the two have to be balanced?
So
ρgV- mg =0
ρgV= mg
No, ρVg and mg are two expressions of the same force.
You have two forces, gravity, G and the pulling force, F.
Newton's law applied to this situation is
F-G=0.
Now you can express G=mg=ρVg
so going back to the first equation,
F-ρVg=0 and
F=ρVg
This is the pulling force in the first case.
Now do the same thing for the case you have buoyant force too. Now you have three forces.
Again, find the pulling force, let say F'.
Buoyancy force is ρgV also though so would I just add that force
F= ρgV for the case in air
So buoyancy (when submerged)
mg= ρgV
Where rho would be that of water in this case where as it would be concrete in the first case
Just write the equilibrium of the forces first. Then you will know if (and where) you add it.
So in water mg= ρgV + F
Where F is the force discussed previously?
Yes, if the ρ is density of water. You should use different symbols for different quantities.
Using ρ for both concrete and water is bad practice.
And the pulling force is different now so you should not use F which was the pulling force when in air.
Call it F' for example.
Now calculate this F' and compare with F found previously.
mg =gV(ρ+φ)
Where phi is the density of concrete
Now, you don't listen.
The "F" in here is not the same as for the air. It is not ρVg or φVg.
It is a new force, F'. This is what you are supposed to find.
Maybe a drawing showing the forces may help you understand.
What value are you going to use as the density of concrete?
2400 kg m^-3
You are not there yet.
Did you find an expression for the pulling force in the second case?
F + ρgV = mg
KiNGGeexD said:
2400 kg m^-3
So what volume of water will the concrete rock displace?
It's the same as the volume of the block!
11K
13K
15K
