How Does Buoyancy Affect a Ball's Movement in Water, Oil, and Moon Gravity?
The discussion focuses on the effects of buoyancy on a ball's movement in different fluids and gravitational conditions. In water with added oil, the ball rises due to the increased force exerted by the oil. When a denser substance is added, the ball remains at the same level as the denser fluid sinks. On the moon, the ball sinks because the reduced buoyant force results from lower gravity. Key concepts include the relationship between the mass of the ball and the displaced fluid mass.
  • Understanding of buoyancy principles
  • Knowledge of fluid density and its effects
  • Familiarity with gravitational variations, particularly lunar gravity
  • Basic physics equations related to buoyancy (e.g., Fb = PA, Fb = gpV)
  • Research the principles of buoyancy in varying fluid densities
  • Study the effects of gravity on buoyant forces, especially in low-gravity environments
  • Explore fluid mechanics concepts related to displacement and density
  • Learn about experimental setups for testing buoyancy in different conditions
Students studying physics, educators teaching fluid mechanics, and anyone interested in the principles of buoyancy and gravitational effects on objects in fluids.
Joe55433454
1a)How does a ball floating 50% in water move when a LARGE amount of oil is added?
1b) if something denser than water were added, how would the ball move?
1c) if the exp. was done on the moon with different gravity and no atmosphere, how would the ball move?
Fb= PA
Fb=gpV[/B]
For question 1a, I believe that the ball would rise because the water would have to exert a greater force when the oil is on top on the ball, since the oil weighs heavier with air.
For question 1b, I think that the ball would remain at the same level because the denser substance would just sink to the bottom.
For question 1c, I said that the ball would sink because there is less of a buoyant force on the moon.[/B]
Can anyone tell me if my answers are correct? I'm not sure if I'm thinking of buoyancy in the wrong sense.
Hi Joe:
Based on the reasoning in tour answers, I think you have forgotten an important concept.
When the ball floats on a fluid, like water or oil, what is the relationship between
a. the mass of the ball,
b: the mass of the fluid which the ball has displaced, that is the mass of the fluid that would fill the volume of the ball that which is below the level of the fluid?
Hope this helps.
Regards,
Buzz
@Buzz Bloom
Wait, why would the mass of the ball change? Because the fluid isn't being inserted inside of the ball.
Hi Joe:
I apologize for not being clearer. I was not assuming the mass of the ball changed. I assume that the volume of the ball below the surface plane of the fluid changes if the density of the fluid changes.
Regards,
Buzz
Is the ball more or less dense than the oil? (You have enough information to answer that.)
Relative to the ground or relative to the water?
But is the weight of the ball the same?
Also, it is not clear whether c is in respect of doing a or b on the moon. Likely it is both, so might require two answers.
I interpret part c differently -- as asking what happens if we take the original ball in the original water, remove the atmosphere and drop gravity by a factor of six.
  • · Replies 21 ·
