How Does Replacing a Sphere Affect Water Level in a Bowl?
The discussion focuses on the effects of replacing a solid sphere in water on the water level in a bowl. Key scenarios include replacing a sphere with a larger radius while maintaining mass, which causes the water level to rise, and replacing it with a smaller radius, leading to a fall in water level due to reduced displacement. The density of the new sphere also plays a critical role, as changes in density can result in various outcomes for the water level, including unchanged, rising, or falling levels depending on whether the sphere sinks or floats.
  • Understanding of buoyancy principles and Archimedes' principle
  • Knowledge of density calculations and relationships (density = mass/volume)
  • Familiarity with the concepts of displacement in fluid mechanics
  • Basic algebra for manipulating equations related to mass, volume, and density
  • Study Archimedes' principle in detail to understand buoyancy effects
  • Learn about the relationship between density, mass, and volume in fluid dynamics
  • Explore the effects of varying densities on buoyancy and displacement
  • Investigate real-world applications of buoyancy in engineering and design
Students in physics, educators teaching fluid mechanics, and anyone interested in understanding buoyancy and its implications in real-world scenarios.
ScrubTier
A small solid sphere of mass M0, of radius R0, and of uniform density ρ0 is placed in a large bowl containing water. It floats and the level of the water in the dish is L. Given the information below, determine the possible effects on the water level L, (R-Rises, F-Falls, U-Unchanged), when that sphere is replaced by a new solid sphere of uniform density.
https://s3.lite.msu.edu/enc/74/b3c49e2ca8cb7c50641a94dd509544cd403157aec9507f20a52bdc5947f0cb19184f2a219a924c3481bb57610950b65b7dd0f547f2f8b7a8b89c27e8be908981d875d7cfcda8738d36912b4c413a1f8c3b2a53a7dd9ca143fd48be3e50ded0c9.mp3
The new sphere has radius R > R0 and mass M = M0
The new sphere has radius R < R0 and density ρ = ρ0
The new sphere has mass M = M0 and density ρ > ρ0
The new sphere has mass M > M0 and density ρ = ρ0
The new sphere has radius R = R0 and mass M > M0
The new sphere has radius R < R0 and density ρ > ρ0
B=mass/volume
1. U
If it is not submerged then the displacement is equal to mass which doesn't change
2. F
This means less mass therefore less displacement
3. U
4. R
More displacement
5. R
More displacement
6. R or F or U
It depends how it effects the mass[/B]
B=mass/volume
1. U
2. F
3. U
4. R
More displacement
5. R
More displacement
6. R or F or U
Not bad, but in a couple of places you wrote "if it is not submerged". You need to decide whether it can be submerged and if so how that affects the answer.
1. R or U
Floating: U mass doesn't change
Submerged: Radius increase means more displacement
2. F
To keep p constant both must fall
3. F or U
Submerged: To get p to be larger with m constant then volume must decrease
4. R
If Mass increases but p stays constant then volume must also increase. Displacement increases in both situations
5. R or U
Floating: R Mass increases therefore more displacement
Submerged: U volume remains constant no change
6. R or F or U
Floating: Mass may or may not increase could be Rise or U
Submerged: Volume decreases therefore F
This is still wrong. I really can't tell why.
ScrubTier said:
1. R or U
2. F
3. F or U
4. R
5. R or U
6. R or F or U
You are told it is floating initially. What you have to consider is which of the proposed changes might result in the sphere sinking, and how that might affect the change in water level.
In 1, 2,4 It would not submerge
so 1. Would be no change because not submerging and mass no change
2. Fall because p being the same, R getting smaller, than M must also get smaller
4. Rise because p is the same, M gets larger
Right.
What about 3, 5 and 6?
Well doesn't it depend on if it actual sinks? Like how much the density changes which I don't know?
That's right. For the cases where the density increases, consider both possibilities. If this leads to different answers for R, F, U, list all those that may occur.
(For at least one of 3, 5, 6, not all of R, F, U are possible.)
  • · Replies 16 ·
