Bus moving toward wall: Doppler effect with sound reflection
3 replies · 7K views · last reply
ReMa
A bus is moving at 37.00m/s towards a wall. The sound from the bus has an original wavelength of 0.1500m. The sound from the bus reflects off the wall. What frequency sound does an observer on the moving bus hear from the reflection??
Moving Observer: fo = fs (1 + vo/v)
v = LaTeX Code: \\lambda f
Is this doppler effect??
vo = 37.00m/s
Since v = LaTeX Code: \\lambda f
vi = LaTeX Code: \\lambda fi
f = v / LaTeX Code: \\lambda
= (343m/s)(0.1500) = 2286.667hz
Subbing into equation:
fo = (2286.667hz)(1 + 37m/s / 343m/s) = 2533hz
Ok, I ALSO tried another method...
Vs = 37 m/s
Therefore the speed of the wavefront is: vs + v
where v = 343m/s (speed of sound in air)
fs = 343m/s / 0.15m = 2286.667hz
Frequency observed is thus:
(v+vs/v-vs)fs = (343+37 / 343-37) (2286.667) = 2839.65hz
Both of these answers are choices in the multiple choice part, so this is becoming a frustrating question for me.
Help appreciated! Thanks!
The frequency of source does not change on reflection. Could you explain the thought behind your assumption in the first part?
I was confused about that too, but am now thinking I misread some of my notes... which would explain A LOT of why that didn't make sense to me.
Could you check my two possible solutions and let me know if either is correct?
Well the second one is right.
I was thinking if frequency and velocity of propagation of sound do not change in reflection wavelength shouldn't change too.
