C++ conditional testing fails, why?
4 replies · 2K views · last reply
John O' Meara
I have a long C++ program that has a few simple statements in it. At the beginning I have ;
#define NUM_DP 10
Further on in the program I have this conditional statement;
short int ct, j;
ct = op2.test(op2.num);
if (ct < (NUM_DP - 1))
for (j = 1; j < 20; j++){
code block
The test function returns a value of ct = 9, why then does the for loop execute . Can't you use constants inside conditional statements? Please help. Thanks.
#define NUM_DP 10
short int ct, j;
code block
Constants are fine in expressions. There are pitfalls for certain defines (side effects and such), but that's not relevant here.
I don't see why it's running the for loop. Mind you, I would use curly braces for the if statement (around the for loop), but that should work. Can't say without perhaps seeing the entire bit of code.
I would suggest you either use a debugger and check the variables right before the if, or add a print in there to see the values right before the if. Something like:
Code:
std::cout << "ct = " << ct << "; NUM_DP - 1 = " << (NUM_DP-1) << "; (ct < (NUM_DP-1)) = " << (ct < (NUM_DP-1)) << std::endl;
You should be able to see right away if the values are other than you think. Note that I just whipped out that line. I think it should be right, but I never assume that until it's compiled and tested. :smile: Make sure to #include <iostream> of course.
It is g++ 4.1.2, that I am using, I am just woundering if it is a bug in the version I have for my RISC OS operating system, there is no gdb debugger for my system only a gdbserver which I think requires a remote gdb to work. I will try butting braces around for loop as you suggested. Thanks.
You might want to check that you haven't accidentally put a semicolon after the if, like so:
if (ct < (NUM_DP - 1));
as that'll indicate an if with no body. Braces shouldn't make a difference, so unless you're using a hacked-up compiler with a modified parser or funny extensions there's no reason to think that they're the cause of the problem, though stylistically they're a good idea.
Also, though unrelated to the problem, you should really avoid macros unless you have some compelling reason to use them. C++ allows you to define well-typed constants. Macros are just direct text substitutions.
static short int const numDP = 10;
