C++ - Determining If A String Contains Any Numeric Digits
  • Context: C/C++
  • Thread starter Thread starter needOfHelpCMath
    C++ Numeric String
4 replies · 10K views
needOfHelpCMath
Set hasDigit to true if the 3-character passCode contains a digit.
Code:
#include <iostream>
#include <string>
#include <cctype>
using namespace std;
int main() {
	bool hasDigit = false;
	string passCode;
	int valid = 0;
	passCode = "abc";
	if (hasDigit) {
		cout << "Has a digit." << endl;
	else {
		cout << "Has no digit." << endl;
	return 0;
Note: I cannot use loops.
Re: i am lost may anyone guide me or show me what to use
You need to be able to determine if a given char value is a digit. In header file cctype, function isdigit is precisely what you want. Here's one solution:
hasDigit = isdigit(passCode[0]) || isdigit(passCode[1]) || isdigit(passCode[2]);
If you don't yet know about the boolean operator || (or), think about using if statement(s).
You could use
Code:
find_first_of
. There's an reference with an example here.
is it possible to use if statements to solve this program
First you need to find if passCode[0] is a digit:
Code:
hasDigit=false;
if (isdigit(passCode[0])) {
  hasDigit=true;
I hope you see that the above code is equivalent to:
Code:
hasDigit=isdigit(passCode[0]);
Next you need to test if passCode[1] is a digit:
Code:
if (isdigit(passCode[1])) {
  hasDigit=true;
So the following code tests whether passCode[0] or passCode[1] is a digit:
Code:
  hasDigit=true;
I hope you see that the above code is not the same as:
Code:
hasDigit=isdigit(passCode[1]);
Now you can finish with one more if statement.
