C++ function to tell whether a group is cyclic
8 replies · 4K views
Jamin2112
Is there anything wrong with my logic and is there any way to further optimize this potentially long-running function? I've put a lot of comments to explain what's going on.
Code:
template <typename ObType, typename BinaryFunction>
bool isCyclic(const std::set<ObType> & G, BinaryFunction & op, ObType & g)
	isCyclic returns true or false depending on whether the group G
	is an cyclic group, that is, whether it can be generated from
	one its elements. Formally, G is cyclic if there exists an
	element g in G such that, for all elements h in g,
	h = g^n for some n.
	bool foundGenerator = false;
	size_t maxN = G.size();
	Guaranteed that for each x in G, x^(maxN + 1) will be in the set
	{x, x^2, ..., x^maxN}. That is the meaning of maxN.
	for (typename std::set<ObType>::const_iterator it(G.cbegin()), offend(G.cend()); it != offend && !foundGenerator; ++it)
		ObType e0 = *it;
		ObType e = e0;
		std::set<ObType> powSet = {e};
		size_t k = 2;
		while (k <= maxN)
			e = op(e, e0); /* Sets e equal to e^i */
			if (powSet.count(e) == 0)
				powSet.insert(e);
			else
				break;
			/* Why the break statement?
			   If e is already in powSet, then we've found a cycle but
			   powSet != G; therefore e cannot generate G.
			++k;
		if (k == maxN) /* true iff (powSet == G) */
			foundGenerator = true;
			g = e;
	return foundGenerator;
A couple of observations:
1. Your algorithm could be more efficient. If ##e## does not generate ##G##, then no power of ##e## can generate ##G## either. Proof: if ##\langle e\rangle## is the subgroup generated by ##e##, then ##e^n \in \langle e \rangle## and so ##\langle e^n \rangle \subset \langle e \rangle##. So you don't have to test all of the elements.
2. Why don't you break out of the for loop when you set foundGenerator = true? [edit I just noticed the !foundGenerator condition on the for loop - I hadn't scrolled far enough to the right to notice it at first. So disregard this observation.]
I haven't checked your logic carefully, so I don't claim that these are the only problems. :-p
Here is another optimization. Let ##|G|## denote the size (order) of ##G##. Then for any element, ##|\langle e \rangle|## must be a divisor of ##|G|##. So, in order to determine whether ##e## is a generator, you just need to check ##e^n## for each divisor ##n## of ##|G|##. So let ##n## be the smallest divisor of ##|G|## such that ##e^n## equals the identity, or equivalently, ##e^{n+1} = e##. There are only two possibilities:
1. ##n## is a proper divisor of ##|G|##, in which case ##e## does not generate ##G##
2. ##n = |G|##, in which case ##e## generates ##G##
Isn't there a potential issue in the case ##e^{(n/k)}## % G == 1, where k could be 2, 3, ... ? I don't know if there is a fast way to determine the smallest m such that ##e^m## % G == 1.
Also, is this potential cyclic field based on a prime number, a Galios field, a Galios binary field, or something else?
rcgldr said:
Isn't there a potential issue in the case ##e^{(n/k)}## % G == 1, where k could be 2, 3, ... ? I don't know if there is a fast way to determine the smallest n such that ##e^n## % G == 1.
I'm not sure what you mean with the notation ##e^{(n/k)}## % G == 1. In general, a group only has one operation, multiplication. (Exponentiation is just repeated multiplication.) What do you mean by the % operation?
In any case, he doesn't need to find the smallest positive ##n## such that ##e^n = 1##, he just needs to determine whether there are any such ##n## which are smaller than (hence strict divisors of) ##|G|##. This is true if and only if the element is NOT a generator. A brute force way to do this would be (pardon my pseudocode):
Code:
isGenerator = true; // until proven otherwise
for (n = 1; n <= N/2; n++) // N = |G|; we only need to loop to N/2 since this is the largest possible strict divisor of N
    if (n is not a divisor of N)
        continue;
    if (e^n == 1)
        isGenerator = false;
        break;
[edit] OK, I think I see your point: it might be more work to check "if (n is not a divisor of N)" than simply to check "if (e^n == 1)" for every n, in which case it might actually be faster without the first "if" block.
Also, is this potential cyclic field based on a normal prime number integer, or Galios prime polynomial, or something else?
I've been assuming that it's just an arbitrary finite group, and that the OP has a C++ class which "implements" the group, i.e. a finite set and a binary operation on the set which obey the group axioms. Jamin - is that correct?
It appears that the goal here is to find at least a muliplicative cyclic group or possibly a finite field where addition, multiplication and their inverses work with a finite set of elements. I did some testing with a binary Galios field composed of 8 bit elements modulo the thirty possible 9 bit "prime" polynomials. A generator e raised to m = ## 2^8 ## - 1 = 255 results in ##e^m## % G == 1. The largest value I could get for m for a non-generator e such that ##e^m## % G == 1, was m = 85 = 255/3. So in the case of binary fields, jbunniii's for loop might be able to stop at n <= N/3, and n <= N/2 should be safe for most types of fields.
Updated it to incorporate that:
Code:
bool GroupTheorizer::isCyclic(std::set<ObType> G, BinaryFunction & op, ObType & g) const
	h = g^n for some n.
	for (typename std::set<ObType>::iterator it(G.begin()); it != G.cend() && !foundGenerator; ++it)
		ObType e0 = *it;
		ObType e = e0;
		size_t k = 2;
		while (k <= maxN)
				powSet.insert(e);
			else
				break;
			++k;
			g = e;
		else
			for (std::set<ObType>::iterator i(powSet.begin()), j(powSet.end()); i != j; ++i)
				G.erase(*i)
				/* Why?
				   powSet is the set of all powers of e0. If e0 does not generate G, then neither
				   does any of its powers.
For most fields, even if e is not a generator, it should cycle through a sub-set of the elements. The inner loop could be changed to something like this:
Code:
        e = e0
        for(k = 2; k <= maxN; ++k)
            e = op(e, e0);   // Sets e equal to e^k
            if(e == e0)      // break if e cycled back to e0
                break;
        if(k == (maxN-1))    // maxN-1 == # of non-zero elements in the group
            // found a generator
