C++ prime number program not compiling with String concatenation
  • Comp Sci
  • Thread starter Thread starter nukeman
    C++ Program Thanks
11 replies · 4K views
nukeman
Ok, I just finished my code for my program. And its not compiling, and I am not sure what's wrong.
Below is an image of the errors and the code.
http://i55.tinypic.com/in8x0y.png
And my full code is below here:
MOD NOTE: I indented the code below to make it easier to read.
Code:
#include <iostream>
#include <cmath>
using namespace std;
bool isPrime(int x)
  int divisor;
  int maxDivisor;
  if (x == 2)
    return true;
  else if (x % 2 == 0)
    return false;
  else
    divisor = 3;
    maxDivisor = (int)sqrt(x);
    while (divisor <= maxDivisor)
      if (x % divisor == 0)
        return false;
      else
        divisor = divisor + 2;
    return true;
int getIntBetween(int low, int high)
  if (low<2 || high>2000)
    return 0;
  else{
    return min + (rand() % (int)(high - low + 1));
int main()
  const int MAXPRIME = 2000;
  int min;
  int limit1;
  int limit2;
  cout << "Enter the lower limit (2, "<< MAXPRIME << "): ";
  cin >> limit1;
  min = getIntBetween(2, MAXPRIME);
  while (min == 0)
    cout << "Please Enter a Number Between (2, "<< MAXPRIME << "): ";
    cin >> limit1;
    min = getIntBetween(limit1, MAXPRIME);
  cout << "Enter the Upper limit (2, "<< MAXPRIME << "): ";
  cin >> limit2;
  min = getIntBetween(2, limit2);
  while (min == 0)
    cin >> limit2;
  String s = "The primes between "+limit1+" and "+limit2+" are ...\n";
  int count = 0;
  for (int i=limit1; i<=limit2; i+=2)
    if (i % 2 == 0)
      i++;
    if (isPrime(i))
      s = s + "i";
      count++;
      if (count % 5 == 0)
        s = s + "\n";
  cout << s << endl;
  cout << "There are " << count << "prime numbers between " << limit1 << " and " << limit2 << endl;
  return 0;
In your getIntBetween function, min is not declared. This variable is declared in main, but its scope does not extend to getIntBetween.
There are a couple of ways you could fix this.
1) Add a 3rd parameter to the definition of getIntBetween, and pass min.
2) Make min a global variable, defining just above your isPrime function.
Hi nukeman! :smile:
You're getting a list with errors.
Each error corresponds to a mistake in your program.
It's a pity your output window does not format the errors nicely, and a number of errors have already scrolled up, out of view.
Either way, the first visible error is:
Code:
listprimes.cpp:75: error: "s" was not declared in this scope
and earlier there will have been an error about "min" as Mark44 remarked.
From the error messages you should be able to deduce what's wrong.
If you tell us what these messages mean to you, perhaps we can help you interpret them.
I like Serena said:
Hi nukeman! :smile:
Code:
No look again. I tried compiling it a few times lol. there is only like 6 errors. Look for the last time I typed in g++
Aha! :redface:
So how do you interpret these error messages?
I like Serena said:
Hi nukeman! :smile:
Code:
Is that what it said? I had a hard time reading the OP's screenshot. It looked like äsä to me, with the quotes appearing as some other character.
Apparently the compiler is treating "s" as something other than a string constant. If so, it's going to have a problem with "i" as well.
Yeah, the PuTTY terminal (in Windows) is apparently mangling some symbols from the remote Linux shell session.
I believe that nukeman is not including the right header file for rand().
The code posted includes <cmath>, but not <cstdlib>. The code is not using any of the functions in cmath, but is using rand(), which is prototyped in cstdlib.
Change this:
#include <cmath>
to this:
#include <cstdlib>
