Geared transmission system question
  • Topic: Engineering
  • Thread starter jojosg
0 replies · 5 views
jojosg
The following figure shows a geared transmission system, in order to minimize the axial force on shaft II, please (1) determine the hand of helical gears; (2) determine the revolution direction of worm gear and its hand; (3) draw the three force components on helical gear 2, bevel gear 4 and worm gear 6.
For helical gears:
Axial force direction rule: Right-hand rule for right-hand helix, left-hand rule for left-hand helix.
To minimize total axial force on a shaft: the axial thrust from helical gear 2 must oppose the axial thrust from bevel gear 4.
Bevel gear axial force always points **toward the large end of the bevel gear**.
Worm drive: Worm axial force = worm gear tangential force; worm tangential force = worm gear axial force. Handedness and rotation direction follow the right/left-hand screw rule.
  1. Helical gear hand selection:Motor rotates gear 1 downward on its right side as drawn.Bevel gear 4 on shaft II has its axial force pointing to the left (toward the cone apex / large end).To cancel this axial force, helical gear 2’s axial force must point to the right.If gear 2 axial force points right, gear 2 is right-hand, and mating gear 1 is left-hand.
  2. Worm (gear 5) hand and rotation direction:Bevel gear 4 drives bevel gear 5, so shaft III rotates downward when viewed from the top.We want worm 5 axial force to be consistent, and the worm must be right-hand.Worm rotation direction: counterclockwise when viewed from the top of shaft III.
  3. Force components summary (this is where I am unsure):
  • Helical gear 2: [itex]F_t[/itex] tangent opposite rotation, [itex]F_r[/itex] radially inward, [itex]F_a[/itex] to the right (to oppose bevel gear axial force).
  • Bevel gear 4: [itex]F_t[/itex] tangent, [itex]F_r[/itex] radially inward, [itex]F_a[/itex] toward the large end (to the left).
  • Worm gear 6: [itex]F_t[/itex] tangent, [itex]F_r[/itex] radially inward, [itex]F_a[/itex] opposite to the worm tangential force.
My uncertainty:I am not fully confident about the direction of the bevel gear axial thrust and the matching handedness of the helical pair to cancel forces on shaft II. Also I am not sure about the worm rotation direction and handedness selection. Could someone check the logic for minimizing the net axial force on shaft II and verify the force directions?
