[C++] Problems with strings MinGW
  • Topic: C/C++
  • Thread starter utkarshakash
    Strings
3 replies · 6K views · last reply
utkarshakash
I'm trying to convert an integer variable to a string using to_string function of string.h header file.
Here's the part of code:
Code:
string numToStr=to_string(num);
However, when I try to compile my program I get the following error:
"error:to_string was not declared in this scope"
I'm using CodeBlocks as my IDE and my compiler is MinGW 4.8.1-4. Can anyone tell me why is this error showing up and how to fix this issue?
string.h contains functions for C-style char* "strings", not C++ strings. Try using '#include <string>' instead of '#include <string.h>'. (or in addition to it, in case you're using both C-style and C++ strings.)
If you want to use the C string functions in a C++ program, #include <cstring> is cleaner than #include <string.h>. The same naming system applies to any other C standard headers you want to use in C++.
<string.h> is "really" C and not C++, even if your C++ compiler eats it without producing any error messages.
Of course you also need #include <string> to use the C++ string functions.
