C# program to add two numbers with looping
  • Context: C#
  • Thread starter Thread starter TheDemx27
    Program
5 replies · 2K views
TheDemx27
Just starting to learn C#. I just wrote this program to add two numbers and loops by looking up syntax etc. There HAS to be a more efficient way to do this.
Code:
using System;
    public class Program
        static void Main()
            bool repeat = true;
            while (repeat == true)
                    string x;
                    string y;
                    int xint;
                    int yint;
                    string useranswer;
                    Console.WriteLine("Enter 'X':");
                    x = Console.ReadLine();
                    xint = int.Parse(x);
                    Console.Clear();
                    Console.WriteLine("Enter 'Y':");
                    y = Console.ReadLine();
                    yint = int.Parse(y);
                    Console.Clear();
                    int answer = xint + yint;
                    Console.WriteLine("{0} + {1} = {2}", x, y, answer);
                    Console.ReadLine();
                    Console.WriteLine("Run again?: Y/N");
                    useranswer = Console.ReadLine();
                    Console.Clear();
                    if (useranswer == "y" || useranswer == "Y")
                        repeat = true;
                    else
                        repeat = false;
That's about as good as it gets, for reading input. C# doesn't have "easy to use" functions like scanf() in C or the << operator in C++. But those easy to use functions are not much use except for toy programs, because it's very hard to catch errors in the input.
You could make the code a neater by "factoring out" the repeated code and writing your own input function, something like
Code:
int getvalue(string prompt)
  Console.WriteLine(prompt);
  string x = Console.ReadLine();
  Console.Clear();
  return int.Parse(x);
xint = getvalue("Enter X:");
yint = getvalue("Enter Y:");
(Note, I haven't actually tested that code!)
Your test for repeating the loop is a bit longwinded. You could write
Code:
repeat = (useranswer == "y" || useranswer == "Y");
or even
Code:
repeat = (useranswer.ToLower() == "y");
You can also make your code shorter by declaring variables when you first use them, instead of by separate statements at the top of a function, as I did in
Code:
or even
Code:
var x = Console.ReadLine();
where "var" means "the compiler can figure out what type of variable this is, so I don't really care".
you could just use a forms app instead of a console app which is much more efficient or
Console.WriteLine("{0} + {1} = {2}", x, y, xint+yint);
maybe that will work its been awhile since I've done a console app. get visual studio it's so superior.
It's advisable to error check all inputs. You can do it like this. Once you get an input, check to see if it really is an integer:
try
Int.Parse(myinputstring);
catch (Exception ex)
Console.WriteLine("That was not an integer.");
And yes, it will probably be needful to use a goto statement, or else, use a flag to create a rather obscure loop, until you get all legal inputs.
And never, ever use Int.Parse without enclosing it in a try/catch, because otherwise your program can throw an obscure error message to the user upon bad input. When I was teaching, that would earn you an instant failing grade.
