C++ Programming Problem: Adding Streams to a Pre-Existing Code
PleaseHelp
I have been given a project to modify my pre-existing code to satisfy these guidelines:
- Create a file called "sides.txt" and put it in the same folder as your program.
- The file contains multiple lines with each line having the three sides, separated by white spaces, e.g.,
3 4 5
6 8 10
5 6 7
...- Declare and define a constructor that gets the sides of a triangle from the valid side values read from the file. Not here that you need to create a function (similar to what's in getSides() in project 3) to validate the sides before calling the constructor;
- Declare and define a global function saveArea() that saves all area values to a file called "areas.txt", located in the same folder.
- It's not required but you are encouraged to use "new" to create pointers to Triangle objects and "delete" to release memory. Then your vector is a vector of Triangle pointers.
- Your sides.txt file should contain at least 5 lines.
I have had some suffered some difficulties understanding the directions and have, therefore, been unable to complete this project. Some help would be appreciated!// This is my code currently
Code:
#include <iostream>
#include <cmath>
#include <vector>
using namespace std;
/*** Triangle class definition ***/
class Triangle {
	public:
		void GetSides ();
		double GetArea ();
	private:
		double side1 = 0.0;
    		double side2 = 0.0;
   		double side3 = 0.0;
void Triangle::GetSides(){
	double sideOne    = 0.0;
	double sideTwo    = 0.0;
	double sideThree = 0.0;
	cout << "Please enter three sides of a triangle." <<  endl;
	cin >> sideOne >> sideTwo >> sideThree;	while ((sideOne<=0) || (sideTwo<=0) || (sideThree<=0) || (sideOne+sideTwo > sideThree) || (sideOne+sideThree > sideTwo) || (sideTwo+sideThree > sideOne)){
		cout << "! ERROR !"<< endl;
		cout << "Using sides { " << sideOne << " " << sideTwo << " " << sideThree << " } will NOT make a triangle." << endl;
           		cout << "Please re-enter three sides of the triangle." << endl;
	cout << endl;
	cout << "Using sides { " << sideOne << " " << sideTwo << " " << sideThree << " } will make a triangle." << endl;
	side1 = sideOne;
	side2 = sideTwo;
	side3 = sideThree;
	return;
}double Triangle:: GetArea(){
	double p               = 0.0;
   	double areaTriangle    = 0.0;
	double a = 0.0;
	double b = 0.0;
	double c = 0.0;
	a = side1;
	b = side2;
	c = side3;
	p                 = (a + b + c) / 2;
	areaTriangle = sqrt( p*(p - a)*(p - b)*(p - c) );
	return areaTriangle ;
/*** End definitions for Triangle class ***/
/*** Functions for vector of Triangle objects ***/void tPrintVector (vector<Triangle>& vTriangle){
	cout << "Printing area of triangle(s). " << endl;
	for (int i = 0; i < vTriangle.size(); ++i){
		cout << "Triangle " << i+1 << " has an area of " << vTriangle.at(i).GetArea() << endl;
	return;
/*** End functions for vector of Triangle objects ***/
int main() {
  	char userInput = 'c';
	vector<Triangle> triangles;
	Triangle temp;
	 // cout << endl << "Press ( c ) to continue, ( q ) to quit." << endl;
	while (userInput != 'q'){
		temp.GetSides();
		triangles.push_back(temp);
		tPrintVector(triangles);
		cin >> userInput;
		cout << endl;
	// tPrintVector(triangles);
	cout << "Done." << endl;
	return 0;
uuum...i have that exact same project from my instructor. with the exact same guidelines. (Speechless)
Hi,
You must understand a little about file I/O. In particular, you need to know about opening and closing a file. Here's a lot of a solution. I have left the saveArea function to you. This program has the function:
void saveAreas(vector<Triangle*> v);
Slightly different from the specification. If you don't supply the vector as parameter, you must make the vector of pointers to triangles a global variable. I try and avoid global variables -- this is good programming practice.
Code:
#include <cstdlib>
#include <iostream>
#include <cmath>
#include <fstream>
#include <vector>
class Triangle {
  int side1, side2, side3;
public:
  Triangle(int s1, int s2, int s3);
  double getArea();
  int getSide(int which);
// It is the responsibility of the caller to ensure the triangle is valid.
Triangle::Triangle(int s1, int s2, int s3) {
  side1 = s1;
  side2 = s2;
  side3 = s3;
// Computes and returns the area by Heron's formula
double Triangle::getArea() {
  double p = (side1 + side2 + side3) / 2.0;
  double a = sqrt(p * (p - side1)*(p - side2)*(p - side3));
  return (a);
// Returns a side of the triangle.  Since sides are private, need such a fn.
int Triangle::getSide(int which) {
  if (which == 1) {
    return (side1);
  if (which == 2) {
    return (side2);
  return (side3);
int isTriangle(int s1, int s2, int s3);
int main(int argc, char** argv) {
  vector<Triangle*> vec;
  int s1, s2, s3;
  ifstream inFile("sides.txt");
  if (inFile.is_open()) {
    while (inFile >> s1 >> s2 >> s3) {
      if (isTriangle(s1, s2, s3)) {
        vec.push_back(new Triangle(s1, s2, s3));
      } else {
        cout << "Input file corrupted" << endl;
    inFile.close();
    saveAreas(vec);
  } else {
    cout << "could not open input file" << endl;
  return 0;
// returns true (1) if and only if s1, s2 and s3 are sides of valid triangle
int isTriangle(int s1, int s2, int s3) {
  return (s1 > 0 && s2 > 0 && s3>0 && s1 + s2 > s3 && s1 + s3 > s2 && s2 + s3 > s1);
// outputs all triangles *v[i] in vector v to file "areas.txt"
// after each triangle is output, it is delete
void saveAreas(vector<Triangle*>v) {
