C# C# Windows Form Game : Movement
The discussion revolves around creating a simple block movement in a C# Windows Forms application using Visual Studio 2010. The code provided sets up key event handlers for moving a player object (a PictureBox) left and right. However, the application does not respond to input because the timer responsible for updating the player's position is not started. To resolve this, the timer should be initiated in the Form1_Load method with `timer1.Start()`. Additionally, it's noted that for proper animation, the form should be invalidated to trigger a redraw, and overriding the form's OnPaint method is recommended for better control over rendering. The importance of ensuring the player object is visible and the timer is active is emphasized for the movement to function correctly.
TheDemx27
C# Windows Form "Game": Movement
All I wanted to do was to make a block move right/left across the window. I'm using VS 2010. No compiler errors and when I run it, it doesn't respond to any input.
Code:
using System;
using System.Windows.Forms;
namespace Game
    public partial class Form1 : Form
        bool right;
        bool left;
        public Form1()
            InitializeComponent();
        private void Form1_Load(object sender, EventArgs e)
        private void timer1_Tick(object sender, EventArgs e)
            if (right == true)
                player.Left += 5;
            if (left == true)
                player.Left -= 5;
        private void Form1_KeyDown(object sender, KeyEventArgs e)
              if (e.KeyCode == Keys.Right)
                    right = true;
                if (e.KeyCode == Keys.Left)
                    left = true;
                if (e.KeyCode == Keys.Left && e.KeyCode == Keys.Right)
                    right = false;
                    left = false;
        private void Form1_KeyUp(object sender, KeyEventArgs e)
                    right = false;
                    left = false;
Technology news on Phys.org
Code:
using System;
namespace Game
        bool right;
        bool left;
        public Form1()
            if (right == true)
                player.Left += 5;
            if (left == true)
                player.Left -= 5;
                    right = true;
                    left = true;
                    right = false;
                    left = false;
                    right = false;
                    left = false;
As far as I can tell from the code that you showed, when the KeyUp or KeyDown events are raised, all that happens is that you're setting the right or left variable, depending on what key has been set. I don't seen any code that actually causes something to move.
You need to start the timer. You can do it like:
Code:
            timer1.Start();
I think that code is here:
Code:
            if (right == true)
                player.Left += 5;
            if (left == true)
                player.Left -= 5;
It should work assuming that the player is visible and the timer is on.
DavidSnider, I saw that code, but not knowing what type a player object is, I couldn't tell that the code did anything.
Sorry: "player" is just a picture box in form1.
Code:
            timer1.Start();
Thanks!
See this assignment: http://harbormist.com/cit597_11/asgn/02_bubblebox.html It's about the simplest code for animation that one can write. Note that you don't actually draw (or move) things in the timer routine itself--you only invalidate the form so that it can redraw itself--and then, to tell it how to redraw, you need to do things by overriding the form's OnPaint method.
At least, that is the way that Microsoft recommends you do it.
  • · Replies 17 ·
