Calculate density of Oxygen at STP
  • Thread starter Thread starter EroAlchemist
    Density Oxygen
The density of oxygen at standard temperature and pressure (STP) can be calculated using the ideal gas law, represented by the equation PV=nRT. For oxygen (O2), the molar mass is 32 g/mol, and the appropriate gas constant R is 8.315 J/(mol·K). When substituting the correct values, including converting pressure from atm to pascals (1 atm = 101,325 Pa), the calculated density of oxygen at STP is 1.43 kg/m³. The initial calculation of 0.007 g/m³ was incorrect due to unit mismanagement and incorrect molar mass usage.
  • Understanding of the ideal gas law (PV=nRT)
  • Knowledge of unit conversions (atm to pascals)
  • Familiarity with molar mass calculations (O2 = 32 g/mol)
  • Basic algebra for manipulating equations
  • Learn about unit conversions in gas law calculations
  • Study the ideal gas constant and its various values
  • Explore the concept of molar mass and its significance in gas density calculations
  • Investigate common mistakes in applying the ideal gas law
Chemistry students, educators, and anyone involved in gas law applications or density calculations will benefit from this discussion.
EroAlchemist
Calculate the density of Oxygen at STP using the ideal gas law
PV=nRT
n = (X grams Oxygen / 16g/mol Oxygen)
I set V = to 1 m3
P = 1 atm
R = 8.315 J/Mol K
T = 273 K
PV = nRT
PV/RT = n
1/(8.315*273) = X grams Oxygen / 16g/mol Oxygen
[1/(8.315*273)]*16 = X grams Oxygen
X = .007g/m3
Book answer is 1.43 kg/m3. I'm way off somewhere.
Thanks for any help!
The SI unit of pressure is the pascal. 1 atm = 101,325 Pa. Try this in the equation and see what you get.
However I'm not sure about the *16 you got, you might want to look that up it doesn't seem right, but I can't remember how you work it out.
Oxygen gas consist of O2molecules. The atomic weight of the oxygen atom is 16 g/mol. The molar weight of the oxygen gas is 32 g/mol.
ehild
As madmike already signaled - watch your units. There are plenty of possible R values to select for to fit units used for volume and pressure, the one you used requires you to use pressure in Pa.
Check out table in http://en.wikipedia.org/wiki/Ideal_gas_constant
  • · Replies 27 ·
